New House Old Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2008, 02:10 PM   #1
new house old basement
Thanks for your opinions on this. Hope this is not an idiotic question, but me and construction go together like oil and water.
We currently live in a Modular home in rural, country area on a farm. We have a basement that goes under the full length of the Modular - about 71 feet by 32 feet, so a rather long basement.
We want to remove the modular and build a new house on our same space, utilizing the basement. Here's my question in a round about way..
The new house obviously is not the same dimensions. From side to side it's much shorter and from front to back, it is longer. Can we utilize the current basement in some way or do we rip out the entire basement and start over, pouring a brand new basement?
Thanks for your input
abkeeper is offline   Reply With Quote
Old 04-21-2008, 02:37 PM   #2
Registered User
Termite's Avatar
You'll need to have a structural engineer look at the existing foundation and footing to determine if it is structurally adequate to support the loads imposed by your new home. There is a good chance that you can use it to some extent. The engineer can use a rebar locator to check for adequate reinforcement, and will also check things like wall thickness, footing dimensions, and drainage systems. He'll also design a way to tie the new portions of wall into the existing portions, which is a connection that always requires an engineer's help (reinforcement and water infiltration).
Your best bet is to first determine if the local code official will allow the engineer's report. Most will, some won't. The I-codes allow use of an approved 3rd party engineer, so local ordinance should be the only hurdle. Since you're rural, you may not even have codes. USE THE ENGINEER FOR YOUR OWN PROTECTION AND PEACE OF MIND. It will probably only cost a few hundred dollars.
Keep in mind that you'll have to tear up portions of your floor to allow for installation of the drain plumbing under the slab.
Old 04-21-2008, 03:33 PM   #3
appreciate your opinion
KCtermite,
Thanks for answering my question - at least now I know this can be done. Good suggestion to get a structural engineer to come up with a plan of action. No use building a new house if we're gonna try to skimp on reworking the foundation. Just wish I'd known what kind of house I wanted when we first got married...was just a giddy, clueless bride back then Thanks for your help!
Old 04-21-2008, 06:29 PM   #4
CrossWorks's Avatar
Rewards Points: 150
If the engineer determines a more than suffcient foundation, you may want to consider using steel floor trusses and have a slab poured over the unused portion and build a garage in place.
But again, it's critical to determine load capacities.
But I see a 32x36 Cape with a nice breezeway and a pretty decent size attached garage in the making here!
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-22-2008, 11:11 PM   #5
Hey CrossWorks,
Great idea with the garage. House will be a Bungalow. No McMansion for us. Can't imagine a giant house with farm equipment scattered around it ala Beverly Hillbillies! Thanks for your response.
Old 04-23-2008, 05:17 AM   #6
CrossWorks's Avatar
Rewards Points: 150
Ya, with the way things are these days a call for big ideas may have to take the back burner. Good luck with everything!
Info/advice needed for basement leak 60 Yr old House pkovo General DIY Discussions 6 01-15-2009 10:40 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Plan for solving basement moisture problem krx Remodeling 1 12-04-2005 07:00 PM
