New Garage-Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2007, 12:02 PM   #1
New Garage-Roof
Building a new garage with a 5 in. 12 roof pitch. The rafter will span 14'. The roof spans 28'. What is the best method used to support the ceiling joist with no bearing partition? What strength should be used for rafter? Am thinking of 2x8. And what strenth for ceiling joist with limited storage above along with drywall on ceiling?
clindrose is offline   Reply With Quote
Old 06-16-2007, 08:43 PM   #2
General Contractor
joasis's Avatar
So I am guessing you are saying the building is 14 wide by 28 long? Or 28 wide, which would be a longer rafter run then 14?
The least expensive way for you to do this is by trusses, spaced 2 feet on center...and you can get them "attic" style, so you would have like a 6 X 6 or so box for light storage.
Length of the building, divide by 2, add one for the number of trusses, and remember that 2 of them should be ordered as gables, so they have framing members at 2 on center vertically. If you have an odd number, you can tight space the ends or center.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 06-16-2007, 11:36 PM   #3
Thanks!
I appreciate your quick response. Your answer was very helpful. Thank you!
garage roof leak Chicago Bill Roofing/Siding 8 05-05-2009 01:07 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
advice for insul./vent. of garage roof? King Dark Lake Roofing/Siding 3 04-15-2007 01:37 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
garage roof problem ERIK2173 Roofing/Siding 3 11-03-2005 07:44 AM
