New Garage Door.. DIY Or Not? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 09:31 AM   #1
New garage door.. DIY or not?
Hi All,
I currently have a wooden door which is all beat up and recently it just wouldn't open. I haven't had a chance to check why the opener is getting stuck(I think it has something to do with the door locking mechanism...
I need a new door and I was considering calling someone but I have started seeing online that it might be a DIY job...
My question is, could I use all existing hardware like rails/spring and the opener? I'm guessing I can measure up the existing door, order a door with the same dimensions and go ahead and attempt the install?
Can someone recommend a door brand and where to buy from?
jmejiaa is offline   Reply With Quote
Old 08-20-2010, 09:33 AM   #2
Old School
Willie T's Avatar
http://www.wayne-dalton.com/resident...age-doors.html
FranÁois Duc de La Rochefoucauld
Willie T
Old 08-20-2010, 10:24 AM   #3
Rewards Points: 558
http://www.hometips.com/diy-how-to/g...tallation.html
epson is offline   Reply With Quote
Old 08-20-2010, 10:27 AM   #4
Also, my current garage only has one spring... Should it have 2?
Old 08-20-2010, 10:46 AM   #5
Rewards Points: 558
Usually each door has its own springÖ
Old 08-20-2010, 10:47 AM   #6
great, so 1 door = 1 spring...
Thanks for the link i had looked at that.. I'm going to compare some pricing and decide if i should do it myself..
Old 08-20-2010, 11:20 AM   #7
Rewards Points: 558
Yup...
Old 08-20-2010, 03:58 PM   #8
Rewards Points: 4,454
that work's extremely competitive &, while we can do the work, i never did like fooling w/torsion bars 1 bit,,, i'll let them put some food on their table long's they stay outta conc & bsmt waterproofing,,, we just ordered a new 18' x 7' - w/3/4hp liftmaster operator, it came to $ 1,800
Old 08-20-2010, 04:01 PM   #9
Yea I'm thinking of leaving it to a pro... I like to DIY but from reading the stuff it might be worth it to pay for the work to be done...
Old 08-20-2010, 04:03 PM   #10
I installed a door with springs at my house
Its Temp until we get the doors we want
Springs I will do......not so sure about a torsion bar
If you are in an area w/cold weather look into an insulated door
Old 08-20-2010, 04:54 PM   #11
Registered User
Rewards Points: 4,924
Things to consider: track, springs, rollers and hardware belong to each door, with some models by the same manufacturer, hardware is interchangeable. The weight of the door determines the spring strength, which have maximum poundage ratings. For a warranty, the hardware will need to match the door. The back-hang angle is important as is the initial setting of the roller distance on the top ones. The good news, most doors have good installation instructions, some adjust the torsion spring/s with a drill motor. Steel cables running through the side springs for safety, new openers most anyone can install. In my training to hang W.D. and others with a torsion bar, the 18" x 3/8" steel bar spring winder came out and shot 20' across the big garage, glad no one was hurt.....
Be safe, Gary
Old 08-21-2010, 02:30 PM   #12
firehawkmph's Avatar
Rewards Points: 1,800
Jm,
I hang garage doors and openers. You are probably best off finding a local garage door installer and let him put the door up. If he is buying the doors wholesale, he can usually install it for about what you would pay at home depot or lowes just for the door. Torsion spring setup is the way to go if you have the headroom above the opening. Clopay makes a decent line of doors and is a nationwide company. Liftmaster makes good openers. Chain or belt drive.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
