Old 04-11-2010, 10:09 PM   #1
Fearless DIYer
Question
New Foundation: Minimum height of concrete above openings
Hi there,
I am pouring a new concrete foundation for my existing house. The foundation walls will be 8' high and 8" thick of 3000psi reinforced concrete. The house has a large 8"x8" beam running along the entire perimeter of the house that will sit on top of the new foundation walls.
I would like to have several openings for 2' x 2' windows in the foundation walls. I would like to place the windows below the top of the wall leaving a span of concrete between the top of the windows and the top of the wall. My question is, what is the minimum height that this span of concrete should be? Obviously there will run rebar across the span, but I am still worried about cracking if I don't go thick enough. I am currently working with 6" of concrete above the windows in my plans.
I would appreciate any thoughts.
Thanks!
axiom10 is offline   Reply With Quote
Old 04-11-2010, 11:02 PM   #2
jlhaslip's Avatar
Is there a rim joist above the windows?
Turn the rim joist into a header sized piece of material and you can place the windows as high as you want to.
Is there an Engineer involved? Ask them.
Or a Building Inspector in your area?
(where are you?)
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 04-11-2010, 11:26 PM   #3
Fearless DIYer
The floor joists are attached by hangers to the 8"x8" perimeter beam, so the beam acts as the rim joist. There would be very little load (none?) on the concrete above the windows.
An engineer would be nice but not in the budget. I am on PEI in Canada.
? RE:Replacing exterior brick with LP lap siding on a poured concrete foundation Greg D Building & Construction 0 11-26-2009 08:49 PM
Sealing around concrete form openings blue_can Building & Construction 4 11-25-2009 07:40 PM
they poured the back foundation wall to the wrong height. Now..... CumminsTruck Building & Construction 14 06-30-2009 12:24 AM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 07:28 AM
Sealing a concrete wall foundation richvoice Building & Construction 7 11-25-2008 03:55 PM
