New Footers For Temporary Jack Posts? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 11:10 AM   #1
New footers for temporary jack posts?
I'd posted in an earlier thread about what was necessary to properly jack up a beam: Proper jacking method?
As I move farther along in the planning stages, I've noticed that the basement floor has a slope to it so that water will move to the floor drain. This is no problem for the new, permanent posts, as they'll be sitting on newly poured and level footings. However, it seems extremely likely that it will be difficult to level the bottle jack / posts and their lumber/metal plate bearing surfaces, and I definitely don't want to create a situation where the jack kicks out because of this. Do I need to pour new, level footers for the jacks as well, or is there an easier way to do this?
revrsemigration is offline   Reply With Quote
Old 11-01-2010, 11:27 AM   #2
why cant you level the jack using a steel plate under a pair of the legs?
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 11-01-2010, 11:28 AM   #3
jlhaslip's Avatar
Rewards Points: 1,564
Shim the low side to level. Once you get pressure on it, you'll be fine.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 11-01-2010, 01:02 PM   #4
Shimming with either a metal plate or wooden shims is definitely an option. For some reason, my brain previously went blank at the thought.
Old 11-01-2010, 01:28 PM   #5
I would stick with steel sink wood might just compress under the point load of a foot (unless your jack has an absolute flat bottom).
you can always jack it up, and built a temporary shoring wall as well if its longer term.
How many jack posts to use to lower one joist? 99miles Building & Construction 3 09-26-2009 11:23 AM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 07:03 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 02:55 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Cracks in pressure treated posts (4x4s, 6x6s) Deck Building & Construction 8 05-15-2008 10:57 PM
