New Exterior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2011, 10:30 PM   #1
New exterior wall
Hello, I plan on removing my garage door and building an exterior wall where the garage door was.
How do I attach the cinder block to the current garage slab?
Tomperro is offline   Reply With Quote
Old 08-31-2011, 06:26 AM   #2
First, make sure there is a foundation under the slab. Older construction may not have had a foundation, and adding a heavy wall could cause that end to break and sink.
Prep for new wall if slab has a foundation. Drill holes in the slab at the center of the proposed wall. Epoxy rebar in the holes. Build a small form(2x4 with rebar) for a low footer on the slab, pour concrete in the form and add block when set. The rebar will hold the new slab.
Old 08-31-2011, 08:53 PM   #3
analogmusicman's Avatar
Rewards Points: 560
I'd check your local code to see if this can be done. some localities are touchy about garages.
tnx,
analogmusicman is offline   Reply With Quote
