New Exterior Door Install - Picture - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 05:10 PM   #1
Rewards Points: 81
I built a small storage shed / garage in my back yard and I am ready to install the prehung exterior door that I purchased. As you can see in the picture there is a concrete floor and block foundation. Do I need to install anything between the aluminum door sill and the concrete? I was planning on just putting a bed of silicon down on the concrete and then shim and screw the jambs. What is the best way to handle this situation?
hartkem is offline   Reply With Quote
Old 02-18-2012, 12:56 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
50 year GE pure silicone. Expensive but good stuff.
Run a fat bead across the dry floor and up the sides a couple inches, and carefully stand the door on the silicone without dragging the silicone everywhere.
Maybe run a little more silicone where the slab meets the trimmers after the door is stood.
Look at the bottom of the door to make sure the best place to run the length of silicone will have plenty contact with the solid portion of the bottom side of the door.
titanoman is offline   Reply With Quote
Old 02-18-2012, 01:38 AM   #3
Rewards Points: 272
on the bottom of the aluminium threshold you will notice there are voids. I fill those voids with spray foam to give it more insulation value as the aluminium tends to transfer the cold from outside to inside. Then I use a good silicone and seal the outer edges.
fixrite is offline   Reply With Quote
The huge water in basement epic picture thread. Money has run out, water hasn't. coderguy Building & Construction 43 06-16-2015 08:36 AM
Paint color for area above picture rail molding NancyNGA Interior Decorating 3 12-16-2011 01:39 PM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 02:13 PM
Toshiba TV, picture goes away pat9999 Electrical 1 07-04-2008 10:28 AM
picture window matjone Carpentry 4 01-03-2008 07:04 PM
