New Door Through Triple Brick Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2009, 06:19 AM   #1
new door through triple brick wall
I have a 1929 Dutch Colonial in the Detroit area, and would love convert a little-used room behind my garage into a mudroom. Doing so would entail a new doorway through the back of the garage into this room.
After doing some investigation, I realized that rather than brick veneer and wood framing, the wall consists of 3 courses of brick. No wood. There is a second story above the area.
I'm going to hire someone for the project, but want to make sure it's done right.
1. Is a mason alone qualifed to do this?
2. What manner of lintel do you suggest?
3. Elsewhere the house has a steel door through brick without wood framing. Could I used this approach in this application?
thanks
Mike F.
Mike.F is offline   Reply With Quote
Old 08-02-2009, 06:49 AM   #2
A good mason contractor should be qualified to do the job. It will need reinforcement on the sides and top. A 1/2" steel 'L' beam should support the structure above. I do not recommend making the opening without side reinforcement of some type. The doorway you mention may have been built before codes.
Old 08-02-2009, 04:04 PM   #3
Thanks for the reply.
I met with a mason who told me a lintel is not required... he's out.
What about a separate lintel for each course? That way one course could be addressed while the other two are bearing the load.
Would a 2x12 rough frame outside a prehung fiberglass door suffice on the sides?
Mike
Tags
brick , door , lintel , wall
brick wall on front of house is leaning Brendawyatt Concrete, Stone & Masonry 6 12-03-2012 07:38 AM
Brick wall in my basement diyinjerseycity General DIY Discussions 1 07-24-2008 04:03 PM
anchoring door in a brick and concrete wall agroux Carpentry 1 05-08-2008 12:28 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Basement leaks in brick wall Nick General DIY Discussions 8 07-18-2006 04:29 PM
