New Deck Overhang Minimum? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2015, 08:11 PM   #1
Rewards Points: 6
New deck overhang Minimum?
I am building a 10' x 15' deck that is 40 inches above the ground. Is there a minimum overhang past the drop beam? I ask because originally I was going to have an 1.5' overhang, but I had to move the posts farther out so now I will have about a 1 foot overhang, is this okay? I am using 2x8x10 for the joists on 16 center. The drop beam will be (3) 2x10 on three 6x6 posts. Thanks
jrod8033 is offline   Reply With Quote
Old 09-14-2015, 10:03 PM   #2
Rewards Points: 5,336
A 12" overhang is fine for a 2 x 8 joist. The question, for me is, what is the unsupported span of the 2 x 8 now?
Ron
B. Franklin 1759
Old 09-14-2015, 10:11 PM   #3
Rewards Points: 6
span
I am attaching the ledger to the house and the joists are 10 feet long. The support beams are approximately 9' from the house, is this what you were asking for? Thanks
Old 09-14-2015, 11:30 PM   #4
Span is good @ 9 feet.
Southern yellow pine(2 x 8)@ 16" on center is good for over 12 feet. That would be a little bouncy for me, but it conforms to the span tables.
Ron
B. Franklin 1759
Old 09-15-2015, 12:19 AM   #5
Rewards Points: 6
Span
Thank you for your help. Would using 12" oc help reduce the bounce, or is it more a function of the joist size? I have an older home and the band/rim joist I am attaching the ledger to is a 2x8.
Old 09-15-2015, 02:39 PM   #6
Rewards Points: 948
2x10 joists on the same centers would be the best solution, which may require a larger ledger. If you can't do that, increasing the centers will reduce deflection. 2x8 can overhang a max of 1'-10" if using 12" centers (prescriptively). A permit will answer those questions for you.
There is no true "minimum" overhang, the rim can sit directly on the beam. For attachment reasons, my preference is to either have an overhang and hurricane clip to each joist, or connect posts directly to rim using post-to-beam connectors (or posts notched and toenailed). A dropped beam with no overhang somewhat negates the benefits of the beam being dropped--and makes connections more critical. With any overhang you need to make sure your attachment provides the minimum uplift resistance per code, and proper backspan ratios (the latter which you appear to have).
Deck guide has good information:
http://www.awc.org/pdf/codes-standar...Guide-1405.pdf
keymaster is offline   Reply With Quote
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
tiling deck of a 5 ft corner tub level with tub deck Blue Falcon Carpentry 16 09-28-2011 12:55 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
