New Deck Ledger Regulations - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 10:26 PM   #1
Rewards Points: 5,336
Anybody see this article in Professional Deck Builder about ledger
attachment to the house and a building code change?
http://www.deckmagazine.com/pdf/2011/1101/1101stru.pdf
I'm confused about the Backfill zone and post placement. How far out from the house is it and at what point in time does it cease to exist?
If a deck is built on a house that was built 30 years ago, is it still classified as a backfill zone?
According to the article, in this area the post needs to be down to the footing( not just below the frost line).
Ron
Old 02-06-2011, 11:11 PM   #2
Registered User
Rewards Points: 5,498
I knew about the 5' rule and posted it on this forum about end of summer in '09. I sited it from the 2006 Deck Code but never researched it further, pp.9;http://www.lancova.com/deckinfo.pdf
Thanks for the info on ledgers....
Gary
Re-attaching Deck to Ledger Board B-Web Building & Construction 5 12-13-2010 08:05 AM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 05:51 PM
Deck Ledger Question Greg D Building & Construction 9 04-08-2010 07:57 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
