New Deck - Gap Between Beam And Post Due To Shrinkage? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 06:56 AM   #1
Rewards Points: 38
New deck - Gap between beam and post due to shrinkage?
I'm framing a new deck built post-and-beam style (no cantilevers) where the joists are in the same plane as the beams. The posts are 6x6 PT SYP on Simpson standoffs anchored to concrete piers, with Simpson Post/Beam connectors anchoring the beams to the post tops.
When I look at the post-beam connections today, I notice that on a few posts, a gap developed between the beam and the post. It's about a fingertip in size - maybe 3/8". I'm surprised that much of a gap developed between the post and beam when the beam was resting on the post two days ago and more than a dozen nails secured the connector.
I'm sure the posts were green, but I didn't expect that much shrinkage in a day or two. It's been brutally hot (+95F) and dry this week. So I'm thinking I should cut out those shrunken posts and replace them with larger ones from the same (now dryer) stock -- or just leave it alone in case (when wet) they'll expand a bit?
Thanks for any help.
DaveNJ is offline   Reply With Quote
Old 07-05-2010, 06:57 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
post don't shrink in the long dimension significantly [or at all] beams do shrink in width but that sounds like alot
Tom Struble is offline   Reply With Quote
Old 07-05-2010, 08:40 PM   #3
Rewards Points: 1,910
What model post/beam connector did you use and how many nails in each? The posts didn't shrink in length. I don't know of any way the beams would shrink away from the posts that much if connectors were nailed properly.
Old 07-06-2010, 07:23 AM   #4
Rewards Points: 1,578
I assume "concrete piers" means they are poured concrete and sunk into the ground and not sitting those concrete blocks that sit on top of the ground?
bob22 is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
Deck Framing - Beams on top of footing (not enough space for post) Maatoy Building & Construction 18 06-02-2010 08:03 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 06:14 AM
Deck Beam - staggered davis_mc Building & Construction 16 07-06-2008 05:27 PM
