New Deck Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 04:38 PM   #1
New Deck Floor
I'm replacing my existing deck floor that is 1.5 inches thick with a new floor that is only 1 inch thick. This change will result in the sill for the door that leads to the deck being 1/2 inch above the new floor. What's the best way to overcome this problem? Replace the sill? Build the framing up by 1/2 inch? Or something else that this DIYer is just not thinking about?
4901 is offline   Reply With Quote
Old 03-10-2010, 08:25 PM   #2
Rewards Points: 5,336
I wouldn't do anything. If you think it might be a tripping hazzard, put an inclined threshold on the deck.
Ron
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
Floor joist / house band question for new deck drewid153 Building & Construction 2 06-10-2008 01:29 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
