New Deck Construction ?'s - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-19-2008, 04:20 PM   #1
Have a few questions regarding new deck construction:
1. Ledger Board:
a. What's the sticky rubberized material placed behind ledger boards called and is it necessary in addition to proper flashing (as seen on This Old House, DIY, etc)? Felt paper comparable substitute? How about the necessity of applying silicon caulk into lag holes prior to installing lag bolts?
b. I have a basement bathroom exhaust vent that was cut through a rim joist in order to vent outside. Can I cut the ledger board (in essence create 2 seperate ledger boards) to keep the location of the vent and use a 90 degree pvc pipe to vent down under deck (location of vent is 3' from edge of left side of deck and would be under decking boards)?
2. Footings:
a. What are the pros/cons of installing posts (either 4x4 or 6x6) in cement vs. using brackets attached to footing and posts? Ditto for use of footing forms?
usmcstormvet is offline   Reply With Quote
Old 08-19-2008, 04:42 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
1. Ledger Board:
2. Footings:
A. the rubber sticky stuff is either grace shield. or ice and water shield.
B. yes you can as long as its in a bay between the joist's. But why not run one long one and drill through it from the inside out?
C. Brackets are made to secure the post to the footing and at the same time to keep the post off grade so it does not rot out prematurely.
Old 08-19-2008, 10:14 PM   #3
Thanks for the quick response. But...
Would like to know if the grace or ice/water shield, or use of felt as substitute, is required?
Looking at the area tonight, I noticed that the bath vent will actually be above the height of the ledger board. I'm building a 33'x7' porch deck. Can't go any higher due to my door threshold. Recommendations to a. lower the vent (requires patching hole and cutting new one in rim joist) or just vent to where it's currently located.
Reading around a bit more on this forum, I see why forms for footers and brackets are used. I also see use of expansion bolts - any reason not to use tapcon?
Thanks.
Old 08-19-2008, 10:20 PM   #4
deck flashing.
http://www.flash.org/resources/files/HGCC_Fact23.pdf
stuccoman is offline   Reply With Quote
Old 08-19-2008, 11:35 PM   #5
buletbob's Avatar
Thanks.
The ice shield would act as a barrier from water. it is just a better way to seal behind the ledger board and house wall.
As for the post cups they should be fastened with a foundation bolt embedded in the footing, I use the tapcon's to hold the cup in line with the girder.I don't know the codes there expansion bolts will work if allowed, Here its 5/8" threaded foundation bolts.
With the dryer vent could you relocate it on another wall.
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 04:09 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 02:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
