New Custom House, Concerns/problems. - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 02:17 PM   #16
concretemasonry's Avatar
Rewards Points: 2,578
Obviously an air exchanger is needed. I needed on in my lake home because it was masonry and use too tight.
Windows are just a hole in a wall and all the films and gasses between the glass layers do little and possibly get the insulation value up to that provided by a plain 8" block with no insulation. The aluminum frames are dramatic conductor that will always be worse than any other material. Frost is a visual clue to the the localized heat loss coupled with excess moisture and poor circulation. - Even in the cold north here, frost on a window is rare in a newer homes.
One basic problem is that the steel frame is virtual radiator and conducts heat/cold very, very efficiently. The fact that is welded to the beams magnifies the heat loss and the energy demands on the heat pump and the associated needs for circulation. It is good you did not use steel studs. Your R-19 insulation is really about R-17 (for wood framing) or R13 (for wrinkled tin studs).
Get a professional (not a HVAC man or insulation contractor) to look at your creation and ask for suggestions.
Dick
concretemasonry is online now   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
New house drywall DISASTER pharm07 Off Topic 13 03-25-2011 03:24 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 11:01 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
