New Construction Windows Smaller Than Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 03:58 PM   #1
Rewards Points: 165
I have purchased a triple ganged window to replace three individual windows in a load bearing wall. The largest width I could get from the company I picked (Pella) is 6 inches narrower than the rough opening in the wall. The wall is finished inside and out, but I will be adding vinyl siding in the future. Can I just add a 2x4 to the RO and screw some plywood to the out side and caulk the seams where it meets the board and batten siding? Otherwise how am I suppose to do this? I really want to get this thing in before winter really sets in here ( I live in CT).
chronojosh is offline   Reply With Quote
Old 11-13-2011, 04:17 PM   #2
Framing Contractor
Rewards Points: 118
With pics, we may be able to help
sixeightten is offline   Reply With Quote
Old 11-13-2011, 05:06 PM   #3
Too Old
Sounds like you are on the right track, you need to fill in the gap properly 2x's will work. Are you setting the windows or are you having them set? Be sure you waterproof and seal the area properly.
At least the windows were smaller and not larger
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 11-13-2011, 05:38 PM   #4
Rewards Points: 165
The windows in the attached picture (hopefully it uploaded) will be removed and as you can see, the inner wall is drywalled. I will have to patch in a piece at the sides of the window but no big deal. How do I properly waterprof and seal the outside where the pieces of plywood butt up against the board and batten siding?
Old 11-13-2011, 05:51 PM   #5
Framing Contractor
Rewards Points: 118
You will need to make sure that the existing header is adequate to carry the load above. As for the trim issue, if ot is only short term, what you propose is probably ok.
Old 11-13-2011, 06:25 PM   #6
Framing Contractor
Originally Posted by sixeightten View Post
You will need to make sure that the existing header is adequate to carry the load above..
Why does he have to do that. The opening will be smaller.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
woodworkbykirk (11-13-2011)
Old 11-13-2011, 06:31 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
exactly as joe stated, all they need to do is reduce the opening size, this is done all the time.. the only time you need to worry a proper header when replacing a window is when your making the opening bigger
my question is why did teh window arrive 6" smaller than what the opening, was it ordered wrong or did you plan to install a smaller window
woodworkbykirk is offline   Reply With Quote
Old 11-13-2011, 06:42 PM   #8
Framing Contractor
Rewards Points: 118
From the pic it looked as though there may be a 2x4 between each window. Hard to tell on the phone pic.
The Following User Says Thank You to sixeightten For This Useful Post:
Ron6519 (11-13-2011)
Old 11-13-2011, 09:09 PM   #9
you might be right six, wouldnt be the first time i saw wood frame windows installed that way. in that case it could be partially why your new window was ordered the wrong size. in either case the replacement should have been measure the width of the outside edge to outside edge of the rough opening.. thus getting a 3 gang window
Old 11-14-2011, 05:10 AM   #10
Rewards Points: 165
The window is 6" smaller than the opening because it was the largest size I could get from pella. I ordered it after finishing the drywall because I thought it wouldnt be a problem getting a window that size(my mistake). As for the head I believe it is a double 2x10 so it should be fine. Is it ok for the ends of the window to not be resting directly on top of jack studs though? Also how am I supposed to integrate the housewrap into the new plywood siding? I have tar paper under the board and batten siding. Thanks again.
Old 11-14-2011, 08:36 AM   #11
Too Old
http://www.youtube.com/watch?v=j8xY5...eature=related
This may help you with understanding how to waterproof. I don't agree with the way they wrap the sides and bottom but that is how they do it. When i set window I put the flashing on the bottom then the sides, set the window (that has silicone on the inside of the nail flange) then install the top flashing over the nail flange with silicone ( make sure the top window paper is behind the house paper). Everything is sealed after window is set with silicone I use Novagard sealant. When you tie in the paper on the house put the house paper under the bottom window flashing paper and seal it, put the side paper over the window flashing paper and seal it, put the header house paper over the window flashing paper and seal it. Use a 1x or something to spread the sealant it will get messy.
I am not in an area that has moisture vapor issues and most of the homes are lathe and stucco. I hope this will helps you understand but it may not be the ideal way in your enviorment.
Old 11-14-2011, 03:54 PM   #12
what size window is it. did you just buy a window that was off the shelf from pella or did you get a custom size window... i can get 7' x 9 ft windows through peter kohler
Old 12-01-2011, 03:23 PM   #13
Rewards Points: 165
Thanks anyways. I ended up added two 2x4's to the inside of the frame on either side. Then i patched in 2 sheets of 3/4" plywood with a piece of housewrap between and caulked the hell out of it. I used 6" wide flashing tape over the nail flange and caulked behind the nail flange (except the bottom). The window is under a 4' overhang so that helps to keep any water from leaking in from the top.
Old 12-01-2011, 03:48 PM   #14
Rewards Points: 150
Just a small comment, the existing windows look kile they have decent mullions. Are these windows load bearing?. If they are, you have to watch the header beam size when you take them out.
Cheers from Oz.
JoJo-Arch is offline   Reply With Quote
Installing new construction windows in old House Fisher252 Windows and Doors 11 10-10-2011 04:01 PM
New Construction Windows Ranhome Windows and Doors 14 10-03-2011 11:08 PM
replacing windows.. modifying a rough opening by less than 2 inches? diy'er on LI Building & Construction 14 09-18-2010 06:43 PM
Replacement Windows Smaller Than Rough Opening stubits Remodeling 1 08-25-2010 06:19 AM
Typical Cost to Install Anderson 400 Windows jombres General DIY Discussions 1 10-16-2009 09:57 PM
