New Construction Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 09:51 AM   #1
New Construction windows
Looking for some ball park figures. I am looking to replace about 8 old windows in my home and was looking at getting New Construction Windows. I plan on going with the andersen 400 series low e4 glass.
The home was built in 1972 and these windows are the original. There are 4 windows on the second floor that would require scaffolding.
With the new construction windows I am also looking to have them replace all the trim ans sills. My wifes cousin who does very good work and works with a very large contracting company said he would do the work on the side. He gave me a price of 8500 dollars. Does this sound about right for labor, materials and the windows ?
Giants6984 is offline   Reply With Quote
Old 11-22-2011, 10:08 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,822
This is the wrong place to come for estimates on windows.
Just call a couple of window installers and get estimates....you don't have to buy them.....estimates are free....and a lot more accurate than we will be.
Old 11-22-2011, 10:27 AM   #3
Rewards Points: 6,652
New construction windows involve a lot of work, and the majority of the cost pricing that you were given is labor, not materials. You can go with retrofit windows, which would bring down your costs 2/3 of not having to pay in the upwards of around $10,000.00. Cheaper to pay around $3700 to $4500 for retro-fit windows, for labor and materials, than new construction.
Old 11-22-2011, 11:11 AM   #4
Framing Contractor
Impossible to give prices over the internet. Not even ball park figures. You have to get other prices from contractors in your area.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-22-2011, 12:35 PM   #5
Thanks for the responses. I will give some contractors a call. I'm
starting to learn there are a ton of variables that contribute to the prices. If anyone can answer if 8500 sounds like a normal price for new construction I'd appreciate it. The windows are all normal sizes.
Old 11-22-2011, 12:41 PM   #6
JOATMON
ddawg16's Avatar
Is that 4x4 or 3x5 or 2x4 or 4x5?
Is that for double paned Low-E? Wood clad or Fiberglass or Vinyl? Is that installed or just the windows?
Is that for 2 windows or 20 windows?
Get the idea? It's about par to asking how much a car cost.
Old 11-22-2011, 03:17 PM   #7
Rewards Points: 150
Some photos of the existing windows would help. Are you sure they need replacing? If it's a question of insulation, the existing windows can be modified. I'm worried newer styled windows could clash with your 1972 house design, no matter how humble it is. It's like putting on Benhur chariot and shiney chrome mags on your 1972 Toyota Corola. The photos will decide all.
Cheers from Oz
JoJo-Arch is offline   Reply With Quote
Old 11-22-2011, 04:47 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,212
as others have mentioned, you'll have to call contractors in your area for pricing.. . most window suppliers have a list of installers that they use for when customers want them installed as well if they dont already have a contractor
in regards to which type of window to get is better, construction or retrofit.. id go with the construction grade without a question ive installed nearly 1000 construction windows of various brands and roughly 50 retrofits... plus serviced windows that were leaking.. retrofits are the ones i see the most problems with. with a construction grade window, to install it everything around it has to be removed so to set it in the opening.. a properly installed construction grade gets a sil pan first, then the window set into a bead of caulking which keeps moisture out and warm air in, from there the nailing flange gets sealed off with vycor or blueskin.. along witha metal cap flashing to seal the top of teh window. witha retrofit your simply replacing the sashes. theres no overlap of a flashing membrane, just new aluminum cladding and some caulking theres also no telling what sorta shape the old frame is like and hte flashing on it.
fine homebuilding did a article specifially on this topic last year, they summed it up as for longevity and peace of mind go with the construction grade, for a quick fix on a budget the retrofit
woodworkbykirk is offline   Reply With Quote
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 08:56 AM
Replacement windows - flashing question smoenra General DIY Discussions 0 11-01-2011 11:07 PM
Replacing Windows? Kyle Remodeling 13 12-17-2009 07:03 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
New Windows installed over old windows Lakehome Remodeling 1 03-14-2009 01:39 PM
