Old 02-14-2011, 01:15 PM   #1
New construction using a replacement window
Lowes had their Pella 20 series windows marked down to around $30. I bought several of them and plan to replace my 35 year-old aluminum windows. Here is where I need guidance.
I am tearing out an outside wall (app. 14' running). I will frame up using 2X4s and cover w/ sheathing/housewrap. I then will set the replacements flush w/ sheathing. I will then case the outside out using Hardi trim, and will return inside with conventional 1 bys.
Is this the way to go? The replacement window is wider than a nail-on, so my interior return will not be as deep.
crewguy is offline   Reply With Quote
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
Window pane replacement help dgbehrends Remodeling 17 11-19-2011 11:06 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 04:33 PM
Replacement Window Installation Cost asr1715 Remodeling 1 02-08-2010 11:26 AM
New Construction Window Installation SanDiego Building & Construction 1 06-16-2009 12:28 AM
