New Construction - No Heat Flowing Through Upstairs Vents - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 03:00 PM   #1
New Construction - No heat flowing through upstairs vents
We purchased our new construction home in September and had no need to turn on the A/C or heat because of the mild temperatures. This past weekend, the temps got down to the 30's and we finally turned on the heat. The heat blows fine downstairs but upstairs is freezing cold. I checked all the vents upstairs (ceiling and floor) and nothing was coming through. What could be wrong?
mzbell is offline   Reply With Quote
Old 11-29-2010, 05:08 PM   #2
Sounds like something basic. Your home is under warranty, call the contractor
mrgins is offline   Reply With Quote
Old 11-29-2010, 05:11 PM   #3
Framing Contractor
You have to call the builder.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-29-2010, 07:28 PM   #4
The ducts that feed the rooms in your house should have dampers installed.
Dampers are used to balance the heat distibution through out your house.
If you have a furnace in a unfinished basement you will likely see galvanized (silver) pipes connecting to a central header that comes off the top of the furnace.
Each of these pipes should be equipped with a small handle that rotates a disk mounted inside the pipe. If the handle is at right angle to the pipe, it means that the air flow in the pipe is blocked. If it is parallel to the pipe, maximum air is allowed to flow.
If you find the damper controls, make sure that they are all parallel and then the air should flow.
Here's a link that explains it! http://www.5min.com/Video/How-to-fix...amper-19945035
Old 11-29-2010, 09:07 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
You could also have a second unit for the upstairs.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
With heat, warm upstairs, cold downstairs. Smitty258 HVAC 11 10-18-2009 10:58 PM
changed thermostat on York Affinity, now no heat? sotwell HVAC 1 03-01-2009 06:34 PM
Help..Emergency Heat Running All the Time KatieB HVAC 4 02-25-2009 05:55 AM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 06:47 PM
