-   -   New Construction - No heat flowing through upstairs vents (http://www.diychatroom.com/f19/new-construction-no-heat-flowing-through-upstairs-vents-88082/)
mzbell 11-29-2010 02:00 PM
We purchased our new construction home in September and had no need to turn on the A/C or heat because of the mild temperatures. This past weekend, the temps got down to the 30's and we finally turned on the heat. The heat blows fine downstairs but upstairs is freezing cold. I checked all the vents upstairs (ceiling and floor) and nothing was coming through. What could be wrong?
mrgins 11-29-2010 04:08 PM
Sounds like something basic. Your home is under warranty, call the contractor
Joe Carola 11-29-2010 04:11 PM
You have to call the builder.
Wildie 11-29-2010 06:28 PM
The ducts that feed the rooms in your house should have dampers installed.
Dampers are used to balance the heat distibution through out your house.
If you have a furnace in a unfinished basement you will likely see galvanized (silver) pipes connecting to a central header that comes off the top of the furnace.
Each of these pipes should be equipped with a small handle that rotates a disk mounted inside the pipe. If the handle is at right angle to the pipe, it means that the air flow in the pipe is blocked. If it is parallel to the pipe, maximum air is allowed to flow.
If you find the damper controls, make sure that they are all parallel and then the air should flow.
Here's a link that explains it! http://www.5min.com/Video/How-to-fix...amper-19945035
jbfan 11-29-2010 08:07 PM
You could also have a second unit for the upstairs.
