New Construction - Insulate Chase ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2007, 02:48 PM   #1
New construction - Insulate Chase ?
I probably know this answer but I will ask it.
I have a chase that I will be installing a direct vent fireplace in.
Should I insulate it ?
Tom
Tcal is offline   Reply With Quote
Old 09-24-2007, 08:29 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Only if it requires insulation for the heating envelope (example: connected to un-insulated exterior walls)
Generally, you can install fire-rated insulation (not standard insulation) in the horizontal area where the insulated rafters (insulated roof-line) meets the chase.
Links on proper insulation to use (mineral wool/rockwool insulation):
http://www.naima.org/pages/resources...q_mineral.html
http://www.specjm.com/mineral-wool.php
- Build Well -
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 02:47 PM
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 08:36 PM
New Job in construction Punk8oy81 Carpentry 4 01-28-2007 07:15 PM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 04:57 PM
