New Construction Flooring Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 02:07 PM   #1
new construction flooring question
This might not be the forum to ask this question, but im building a new house here in Wisconsin. Nothing fancy, 1200 square foot 2 story. I tried searching here for Allure Traffic master vinyl flooring, but most threads were remodel questions. My question is I have 3/4 plywood for the subfloor, glued to the I joists, do i just lay the flooring over top of that? or do i have to add more wood to make it thicker? someone said maybe lay some special paper, or even tar paper down. Just thought id find out if any of you guys have used this in new construction before. thanks!
bgabrielse is offline   Reply With Quote
Old 12-05-2010, 02:13 PM   #2
Rewards Points: 5,336
You just look at the manufacturers instructions and follow them. Laminate floors require a foam padding under them. If this is a floating floor, it just lays on top of the floor you have. High moisture areas require a vapor barrier.
All this info will be on the Allure website.
Ron
Old 12-05-2010, 03:36 PM   #3
Which floor is this? If you're laying wood on slab concrete, it's going to rot.
ConcreteTreat is offline   Reply With Quote
Old 12-05-2010, 04:28 PM   #4
thanks guys. it would be the allure traffic master plank floor. it is a floating floor, i just didnt know if i had to put anything more down. Its 3/4" OSB
Old 12-05-2010, 04:51 PM   #5
In that case, I believe you'd be all set. :-)
Old 12-05-2010, 04:52 PM   #6
No. Just the padding that comes with it.
mrgins is offline   Reply With Quote
Laminate flooring question AngeloUCF Flooring 4 11-01-2010 10:13 PM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 09:48 PM
Mannington Flooring Installation Question marlon71usa Flooring 3 12-10-2009 03:24 PM
Question about linoleum flooring JZ2008 Flooring 2 02-24-2008 07:59 PM
sub flooring removal question matchley Flooring 7 10-02-2007 08:19 PM
