New Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 10:46 AM   #1
new construction
i have a concern about installing my framing walls 2"x 6" ontop of the floor joist and 3/4" plywood plateform that now sits ontop of my 10" block foundation/p.t top plate. should the walls of this 2 story structure be placed on the outside edge of the floor joistplatform as to be flush with outside of 10" block foundation or should i center the walls so that the distupution wieght of the walls are evenly spread to the foundation, as apposed to the wieght being on the outside of the 10" foundation??? it seams to make more sense to have the wieght in the center of foundation but then would need to some how flash that water away from the setback , is there anydraw back to stting these walls flush with the outside also should i allow a set back for exterior wall covering such as exterior insul board and siding??? any input would be appreciated ! thank you !
RonPaul2012 is offline   Reply With Quote
Old 03-30-2012, 10:52 AM   #2
joed's Avatar
Rewards Points: 12,464
The platform is set depending on the wall finish. If brick then the platform is set back to allow for brick ledge. The walls on top of the platform are normally set even with outside edge of the platform.
Old 03-30-2012, 11:57 AM   #3
Rewards Points: 1,092
Ron: Surely your block wall goes down to a footer, right? Having the blocks in the center of the footer is, to me, more important that where the wall sits on the blocks.
So, what type of construction is my house Tonglebeak Building & Construction 8 12-01-2012 10:45 AM
Books that teach the basics of construction - recommend them to me? costafinkel Building & Construction 13 08-04-2011 11:32 PM
Can lights in insulated, existing construction? mtr_can Electrical 1 07-16-2011 08:03 PM
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 06:05 PM
Which is better? (Non-vented roof construction with indoor pool) elbartee Roofing/Siding 21 03-26-2008 11:05 PM
