New Concrete, How Long To Wait To Install Powder Actuated Fasteners - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 05:44 AM   #1
Rewards Points: 150
poured a 1'x10'x6" slab at the transition of my garage/driveway.
How long should I wait before securing framing with powder actuated fasteners? Or am I better off using tapcons?
johnnyboy is offline   Reply With Quote
Old 09-12-2010, 08:02 AM   #2
Civil Engineer
Rewards Points: 4,686
Personally I like the powder actuated fasteners, however they are normally used in full strength concrete, which typically requires 28 days for full cure. Check with the manufacturer of the fastener to see if the specific product you are planning to use can be used in partially cured concrete.
I am not sure how much strength the concrete requires for Tapcons, possibly the Tapcon website has the data. Typically concrete acquires at least 25% full strength in 3 days, 50% in 7 days, and 100% in 28 days. If you use a fast set mix, you get strength much more quickly.
Old 09-12-2010, 11:29 AM   #3
jlhaslip's Avatar
Rewards Points: 1,494
On fresh concrete, you can use 'common' nails (the thick ones) the following day without pre-drilling.
After a couple of days, drill a slightly oversized hole, insert a piece of tie wire bend in half and a suitably sized nail and hammer it in.
Power actuated nailing is for cured concrete and steel.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 09-12-2010, 11:39 AM   #4
Registered User
Rewards Points: 5,482
"poured a 1'x10'x6" slab at the transition of my garage/driveway. " ------ sounds as if the truck is longer than the garage.... IF extending garage, use wedge anchors after curing if you forgot the "J" bolts. Add a sill sealer under the p.t. plate for a capillary and thermal break from the concrete. http://www.greenbuildingadvisor.com/...-building-code
Gary
Old 09-12-2010, 12:13 PM   #5
Framing Contractor
How far off the grade is the top of the slab? What is the framing for?
Joe Carola
Joe Carola is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Install manholes (access) hole in concrete septic tank cover rkpatt General DIY Discussions 2 02-23-2009 06:37 PM
thickening the consistency of concrete & does aerated concrete come in a powder artist1 General DIY Discussions 7 02-28-2007 09:09 PM
