New Concrete Block For Foundation Under Ground. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 10:12 PM   #1
New Concrete Block for foundation under ground.
I have redone a foundation wall in my basement, 8' high, 7' will be filled back in, I was told to parge the outside and than tar it, do I need to parge it, and what should I use to waterproof the out side wall.
LuigiT is offline   Reply With Quote
Old 10-27-2010, 10:34 PM   #2
Rewards Points: 1,092
Your local concrete/cement place should be able to tell you. Perhaps something as simple as DryLoc will work; it is supposed to penetrate concrete well, and is used to prevent water wicking in. Ask about bituthane on clean blocks, if you don't mind; I'd like to know if that will work there. thanks. j
Old 10-28-2010, 11:13 PM   #3
Rewards Points: 4,526
all the following prior to backfilling a, hopefully, properly excavated workspace according to osha rules
you don't need to parge it however you DO need to waterproof it including the addn of a toe drain placed in a filter cloth #57 stone filled trench hopefully leading to dayight,,, ' drylock ' type products may rarely work for some but not for pro's - don't waste your $$$ & cause $$$ nitemares later on by depending on it to stop water penetration,,, use fiber-reinforced roofing cement for the wtrproof coating & protect it w/ ( delta-drain OR miradrain )
your block wall should be backfilled in compacted ' lifts ' w/o the use of vibratory, jumping jack, OR plate compactors,,, remember, all that dirt came OUT of the hole & reasonably should fit back in.
we do this work for a living & NEVER recommend ' drylock ' type products below grade ESPECIALLY on a negative-side application
Old 10-29-2010, 03:17 AM   #4
itsreally: thanks for the info. is bituthane ever of use over concrete blocks? too spendy? useless? j
Old 10-29-2010, 06:59 AM   #5
great stuff but you'll generally find it spec's only on commercial OR govt projects, not residential
Old 10-29-2010, 08:43 PM   #6
Concrete & Masonry
Rewards Points: 524
I'd actually recomend the parge/plaster coat, as it creates a better/smother substrate to accept the waterproofing IMO.
Agreed.
Agreed.
I'm not sure I'm reading this correctly, how do recomend he compacts it w/o the use of any of these?
No Dry-lock reccomendation here either...........
jomama45 is online now   Reply With Quote
Old 10-29-2010, 10:09 PM   #7
we'd skip the parge coat in favor of trowel'd on sonolastic but none of the asphaltic emulsion stuff in 5gal pails,,, don't you guys out there gots feets ? our amigos walk back & forth its call'd ' manuel compaction '
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
building concrete steps cinder block frame? drewhart Building & Construction 2 06-10-2010 02:48 PM
concrete block christoff Off Topic 2 06-07-2010 07:00 AM
Framing over concrete foundation (above ground) rovers1973 Building & Construction 1 04-11-2010 04:49 PM
Parging Concrete Block mlenker Building & Construction 2 03-02-2009 09:52 PM
