Old 07-10-2009, 12:37 PM   #1
Default New ceiling within an existing room? Is it possible
When we bought our home we removed a drop ceiling in our 5 x 7 bathroom. Problem 1 is we have a fan that was installed beneath the original ceiling. We want to keep the fan, but obviously want to put greenboard up to cover the housing of the fan and wiring. Problem 2 is the shower surround that was installed goes almost to the original ceiling.
Questions I have...Is it feasable to run 2x4s around the bathroom walls and tie them in through the plaster into the studs? If so, I obviously need to run joists overhead to support the greenboard. How can I tie them to the 2x4s running around the edge? I thought maybe using decking brackets??
I have been pondering over a good way to redo this ceiling, and need help asap. I have attached pictures becasue I know this probably sounds stupid, and may have never been done before
new-ceiling-within-existing-room-possible-bathroom1.jpg   new-ceiling-within-existing-room-possible-bathroom2.jpg   new-ceiling-within-existing-room-possible-bathroom3.jpg
bennett12 is offline   Reply With Quote
Old 07-10-2009, 12:46 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
I'd take the ceiling down
Redo the wiring & fan
Then put up a new ceiling
Scuba_Dave is online now   Reply With Quote
Old 07-10-2009, 01:11 PM   #3
Thanks for the feedback. However, as you can see from the picture the hole for the exhaust is below the ceiling line. In addition there is only 2x4s above the existing plaster ceiling. There was an attic that was above the bathroom before the upstairs was finished many years ago. Not enough room for that. Thanks though!
Old 07-10-2009, 11:05 PM   #4
If you install 'ledger boards' on opposite walls and then install the 'joists' with joist hangers for support, you should be good.
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip we will be showing you step one for painting our ceiling. Before we get started painting our ceiling we first need to remove anything that is on the ceiling. This includes our ventilation... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we will be replacing a bath fan grill. In this bathroom we have a ventilation fan located on the ceiling. Now there's an old 1980's yellow colored grill covering this fan. In addition to it... Read More »
How to Pick Ceiling Fans
How to Pick Ceiling Fans by Expert Village
Hello! My name is Adolph Ramirez from Tampa, Florida and on behalf of Expert Village, this is how to install a ceiling fan. Some of the things that you need to consider before selecting a new fan for your home are fan size height from the ceiling, blades... Read More »
Hi I'm Drew Finn here for expertvillage.com we are going to show you how to install garage door opener today this is being filmed by Black Dog Video you could visit us at blackdogvideo.biz. Now we are going to mount the drive head to the ceiling. First... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and a insulation inspection on this home. A lot of the problems come when we have a vaulted ceiling versus a dropped ceiling. What I... Read More »
Old ceiling replacement idsp General Discussion 12 07-25-2009 12:48 PM
Snow in attic through mushroom vents,leaking into great room ceiling thom risley Roofing 5 01-01-2009 02:51 PM
How to wire a 2-prong lamp to a ceiling mount with an existing ground cyantific Electrical 1 08-19-2008 07:22 PM
What type of ceiling should I use? dzimmer88 Remodeling 2 09-25-2007 05:18 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 01:23 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
