New Car Port - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 08:58 AM   #1
New car port
I have had a new concrete car port also stamped it was too hot when they poured the concrete 45degrees I live in Spain,it set too quickly. The builders now want to pour new concrete over the old and re stamp,will this work?
Gillie is offline   Reply With Quote
Old 10-06-2012, 05:07 AM   #2
I'm no expert, but I would think that they should remove the old concrete first, if it hasn't been set correctly it could be unsound.
Gissle is offline   Reply With Quote
Old 10-06-2012, 05:09 AM   #3
Rewards Points: 13,450
Old does not like to stick to new concrete. I can see this failing.
Old 10-06-2012, 09:16 PM   #4
Rewards Points: 150
It could work; and it could not work out; I speculate that the builder will want to do the new layer only a couple of inches, 6 - 7 cm, thick and if so it is a recipe to a likely problem not too far into the future. It would be best to break up the existing and place new concrete. Over 80 F, 26 C, you need to know what you are doing and adjust your mix, at 45 C, 112 F, you could easily have problems, it is more difficult to work with for the finish and it is more likely to have shrinkage problems and not develop full strength.
TheCamper is offline   Reply With Quote
Lennox 80MGF3-75A Inducer Port Clogged jay235 HVAC 3 04-25-2012 06:00 PM
Furnace port, and combustion chamber crack question. cjf1980 HVAC 0 07-27-2009 09:23 PM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 12:02 AM
