Old 11-02-2009, 07:17 AM   #1
Default New Build - Roof Design
I am currently drawing plans for a future home build. I need to know the feasibility of a shed (lean-to, mono slope) style roof. What are the span limitations? Truss designs available? In particular, I need to know what the maximum spacing between trusses would be. I'm planning a horizontal span of 32' with a 4/12 pitch and a total roof length of 64'. I'm hoping to design this single story with very open, vaulted ceilings (basically no attic). I'm assuming I will need to come up with some sort of traditional rafter/truss hybrid system? I am very new to this and I'm sure I've left out many important details. So please ask for any further information needed. And don't hesitate to tell me that my plan is not feasible. Thanks
jw_shade is offline   Reply With Quote
Old 11-08-2009, 08:38 PM   #2
anyone have any suggestions? I am new this forum but was hoping for some kind of general input
Old 11-08-2009, 09:07 PM   #3
You are going to want to go to your truss company of lumber supplier and have them run the engineering specs on your layout. I have seen mono trusses that were close to that size, but you will have to provide the truss company with the load points. If you use a mono truss you will have a shallower pitch on the bottom of the truss then on the top side of it. The only other way you might be able to do it is with an I-joists. They might make it that span, but again you have to have the lumber company run the engineering.
RobQuillin is offline   Reply With Quote
Old 11-09-2009, 03:41 AM   #4
I might be remembering this wrong, but I believe it used to be said that the blue board acts as at least a partial vapor barrier. The pink stuff was reported to be vapor permeable. This would make a difference if moisture is an issue. The blue board also has a radiant insulating layer, which also can be useful.
wwww caisse d epargne fr | La caisse d'epargne | caisse d'epargne
stihowhir is offline   Reply With Quote
Old 11-09-2009, 07:37 AM   #5
http://www.ilevel.com/literature/TJ-4000.pdf
Here's a link to a popular I-joist company. It has a lot of technical data in it, but the longer you read it, the more you understand. There is a table almost all the way at the bottom of the page for roof application span limits. From the info you provided, it looks like the max span is around 31'-8". So you are right around the max for this type of rafter. It also specifies that a support beam is needed at the ridge. A ridge rafter is not sufficient. That being the case, an engineer would have to come up with something. If you choose to go with this type of roof, you will have to modify your plans to meet their specifications. I think if you shop around, you will find that trusses will be quite a bit more expensive, so it might pay to slightly modify your plans, to stick with I-Joists. There is contact info on the page also.
While an open floor plan is very attractive, I would like to point out that at the highest point, your ceiling will be around 20 or more feet tall. Depending on your area, and how high your heating costs are, you might end up paying an arm and a leg for heat. I went into a house once to change the light bulbs in a very high chandelier. I almost passed out from the heat. It was upwards of 95 degrees up there!
CustomBuild is offline   Reply With Quote
More On This Topic
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
low slope roof want stop leaking kaju Roofing 14 09-16-2009 11:19 PM
roof overhang knee brace design schmolze Building & Construction 3 05-20-2009 04:37 PM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 05:42 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
