New Brick Steps Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 09:05 AM   #1
Rewards Points: 34
Hey guys,
My neighbor just installed these new beick steps, I didn't get a chance to see how they were being build.
Is there a concrete base under each step? Also how do you keep the bricks from poping is they are on concrete, as I would think as you lay brick, the back has to be parged against the vertical concrete riser, otherwise water will get behind it, and pop them.
Also here ia a picture of the type I need info on.
Gladiatorx is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
Repointing brick on front steps gruntman Building & Construction 52 07-07-2012 05:27 AM
Need brick info Thurman General DIY Discussions 9 12-04-2009 02:56 PM
HOW: Wood railing/posts attached to brick steps? TheHiker Building & Construction 1 03-27-2009 06:14 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
