New Basment - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-04-2010, 05:13 PM   #1
new basment
We have a cottage with a new basement . We were told that we have to have heat on in the winter. We do not use the cottage in the winter, the water is turned off, but we will leave heaters on ONLY in the basement.
My husband is concerned about the heat getting to the walls, and is wondering if we put up drywall with insulation, that we will have to leave the heater at a higher temperature, so the walls will be warm.
Can anyone give us any information, on the correct way to heat/insulate the basement, when only the basement is warm, and not the rest of the cottage.
Thanks for any replys
Carol
cottagelife is offline   Reply With Quote
Old 07-04-2010, 06:28 PM   #2
Where is the cottage located ?
Old 07-04-2010, 07:16 PM   #3
new basement
Our cottage is located near Orangeville Ontario
Old 07-04-2010, 09:07 PM   #4
If the cottage is not used in the winter then the proper thing to do is set the cottage up to be winterized each year
That means water lines are drained completely
Anti-freeze in toilets & traps
Insulation & heat tape on the main water line where it is exposed
Once you rely on heat to prevent a problem you must then make sure the heat is always on
Otherwise a power or heat failure will cause a lot of damage
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 02:26 PM
Basment OSB Subfloor unlevel diy-dude Flooring 1 12-11-2009 10:23 PM
Framing & Insulating basment concrete walls harddy Building & Construction 8 12-02-2009 12:04 PM
Ceramic tile in basment blk90s13 Flooring 12 04-09-2009 04:17 AM
Basment block mortar joints crumbling, 40's era 4just1don Building & Construction 1 09-03-2008 10:09 AM
