Old 11-30-2009, 03:27 PM   #1
New Air Conditioner and Brick Veneer
Greetings,
I would like to install an airconditioner through the wall in my garage. The wall inside is sheetrock on 2x4 studs, the wall outside is brick veneer. I am looking for guidance on the installation. My question is do I need to install a angle iron lintel at the top in the new opening made for the air conditioner? There is roughly 4 feet of brick above the opening. The veneer is also tied to the studs with metal tie strips. If I do need a lintel, is there any reason I can't simply remove the grout from the top brick joint which is at the top of the opening and slip the lintel in from the back side?
Any thing else I need to think about?
Thanks for your help and guidance?
RayB1 is offline   Reply With Quote
Old 11-30-2009, 07:08 PM   #2
Originally Posted by RayB1 View Post
Greetings,
Sorry, can't help with the lintel question but one other thing to think about is proper flashing. This could easily become a point for water intrusion. Flashing on top of the a/c case will need to lap up under the wrb behind the brick. I don't see how to do it properly without making the opening larger than the case, installing the case and flashing, and then re-lay the bricks around the case.
Old 11-30-2009, 09:54 PM   #3
That's basically what the mason did in my basement (cmu with brick veneer) when I increased the size of a window to 4' high x 5' wide. I was surprised when he said it was no problem to cut out the brick first and then grind mortar back so he could install the lintel.
The harder part is that you are supposed to take out the brick in a step pattern so the bricks can be cut in half and make a clean edge on the sides (look at your other window openings), and a sloping sill. Then you have to try to match the mortar color.
walkman is offline   Reply With Quote
4" Hole for portable air conditioner bossman7076 Plumbing 2 05-06-2007 12:00 AM
