New *ahem* Asphalt Driveway Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 07:05 PM   #1
New *ahem* Asphalt Driveway question
New Driveway , soft asphalt!
I just had my driveway redone by a licensed contractor. there are a lot of soft spots in the asphalt, my thumb can even wiggle a hole into it. Is there any way I can get around this problem without suing the *&$% out of the contractor? I did give him a second chance to correct this, he tried, he failed. Now he tells me there's nothing he can do about it. any suggestions on how to not start over from scratch would be appreciated. Thank you for your time.
BTW, he told me he used the hot stuff and rolled it. Unfortunately I wasn't around when it was done.
gunji is offline   Reply With Quote
Old 06-22-2010, 07:27 PM   #2
kwikfishron's Avatar
Rewards Points: 414
Is the contractor also the asphalt supplier?
kwikfishron is online now   Reply With Quote
Old 06-22-2010, 08:45 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
from what little I know about asphalt, it sounds like there is not enough aggregate for the amount of the asphalt. The asphalt is simply a binder for the aggregate. It has no strength in itself. It is the aggregate that is what provides any strength. If you can put you thumb into the material, there is obviously no aggregate there.
again, not knowing a lot about asphalt but I cannot think of any way to repair an installation using substandard materials without removing what has already been laid down and starting over.
I would hope so as that is how asphalt is installed. It doesn't mean he used a quality product though.
Old 06-22-2010, 09:48 PM   #4
Concrete & Masonry
Rewards Points: 548
Personally, I'd call a competator or two of his and see if they'd be willing to take a look for you, even if they have a minimal charge. Their professional opinions could be worth their weight in gold in litigation. They may also tell you that the problem is minor, who knows?
jomama45 is offline   Reply With Quote
Old 06-23-2010, 02:40 AM   #5
Rewards Points: 410
He may not have rolled in down enough is my thinking.
Does your aggregate seem closely spaced.
New asphalt driveways are very soft for quite a while though .
Post a picture , maybe there's a professional here.
High Gear is offline   Reply With Quote
Driveway prep Ultrarunner2017 Building & Construction 2 10-11-2009 11:51 AM
Question about convrete driveway Laser4G63 General DIY Discussions 8 02-12-2009 05:19 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Asphalt Question javan General DIY Discussions 5 07-16-2008 06:38 AM
asphalt grindings driveway DIY? johnny331 Landscaping & Lawn Care 2 09-28-2007 04:37 AM
