Old 10-11-2007, 09:45 PM   #1
New addition foundation question
Guys,
I currently live in a spec colonial house with a block basement that is finished.
Attached I have a poured slab garage that has a block foundation.
What I would like to do is to create a 'bump out' in the intersection of these two structures that are attached. This is to expand my kitchen.
I know that I will need to add on to the foundation but the concrete block will not tie into the existing block.
What are your thoughts for building this so that I don't get a possible mis-alignment of separation of the new block from the old.
Note: The new foundation will be below the frost line as per code.
Thanx...
Chris
ccevans6 is offline   Reply With Quote
Old 10-11-2007, 11:06 PM   #2
Why wouldn't the new block tie into the old block if it's bumping out off both structures?
Ron
Old 10-12-2007, 04:34 AM   #3
The old block is actually the outer basement wall and I am not planning to extend the basement. This is going to be a first floor addition.
Old 10-12-2007, 12:40 PM   #4
It doesn't matter if the addition is over a crawl space or a full basement, you still need to tie the addition footing and foundation into the existing structure. That means a physical attachment of some sort.
Who drew up the plans for this? Is this a structure out in the boonies that doesn't need building dept oversight? No building dept would issue a permit for this construction unless your plans conform to the building code.
Ron
foundation question for building a small cabin TNeat Building & Construction 3 08-01-2007 07:08 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
Foundation question jerome8283 Building & Construction 3 01-18-2007 04:06 PM
Addition Foundation /Build. advice wannabuild Remodeling 3 12-15-2006 07:28 PM
Foundation movement question kelly001 Building & Construction 5 10-02-2006 07:09 AM
