-   -   New addition foundation question (http://www.diychatroom.com/f19/new-addition-foundation-question-12312/)
ccevans6 10-11-2007 08:45 PM
Guys,
I currently live in a spec colonial house with a block basement that is finished.
Attached I have a poured slab garage that has a block foundation.
What I would like to do is to create a 'bump out' in the intersection of these two structures that are attached. This is to expand my kitchen.
I know that I will need to add on to the foundation but the concrete block will not tie into the existing block.
What are your thoughts for building this so that I don't get a possible mis-alignment of separation of the new block from the old.
Note: The new foundation will be below the frost line as per code.
Thanx...
Chris
Ron6519 10-11-2007 10:06 PM
Why wouldn't the new block tie into the old block if it's bumping out off both structures?
Ron
ccevans6 10-12-2007 03:34 AM
The old block is actually the outer basement wall and I am not planning to extend the basement. This is going to be a first floor addition.
Ron6519 10-12-2007 11:40 AM
It doesn't matter if the addition is over a crawl space or a full basement, you still need to tie the addition footing and foundation into the existing structure. That means a physical attachment of some sort.
Who drew up the plans for this? Is this a structure out in the boonies that doesn't need building dept oversight? No building dept would issue a permit for this construction unless your plans conform to the building code.
Ron
