New Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-08-2013, 09:30 PM   #1
marklienhardt's Avatar
New addition
Firstly I'd like to introduce myself. I'm new to this site and I'm from calgary alberta Canada.
I will be building a 8x10 mudroom off my 2009 house
Question is should I do a footing with concrete foundation wall tied into my current house or do post beam footing. Such as sono tubes filled with concrete ?
marklienhardt is offline   Reply With Quote
Old 09-08-2013, 09:37 PM   #2
Rewards Points: 12,790
Footing and foundation would be the best way.
Checked with your local code office to see what that say?
Duckweather (09-09-2013)
Old 09-09-2013, 12:29 AM   #3
That's what I'm thinking too. So If I do 3 foundation walls ( u shaped ) then having the 4th being the existing house,how would I insulate under the new floor ? My house is about 2' above grade. So ill have about 6' walls. 2' of that will be above grade.
Could I frame a entry way like a 2x2 hole in the foundation ?
Old 09-09-2013, 05:33 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 996
you really have to check the alberta codes, im on the east coast and were allowed to put a small addition on piers no problem.. the biggest issue is getting the right r value in the floor, we typically spray foam floor systems like this
woodworkbykirk is online now   Reply With Quote
Old 09-09-2013, 09:06 PM   #5
Haverhill Trade 1965
Especially if you want it to stay attached to the house. No matter what, unless your new foundation is on the ledge it will settle a little, or more with sono tubes. I even used extra wide footings for additions, and strip footings instead of pads for lally columns.
Duckweather is offline   Reply With Quote
Old 09-15-2013, 10:50 PM   #6
Thanks for you replies. Much appreciated you guys have any reviews on Screw Piles?
Addition between garage and home themuchky Building & Construction 10 01-26-2012 07:20 PM
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 05:12 AM
Footing/Foundation for Addition stubits Building & Construction 1 03-11-2009 02:43 PM
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 06:06 PM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 08:59 PM
