-   -   New addition (http://www.diychatroom.com/f19/new-addition-186700/)
marklienhardt 09-08-2013 08:30 PM
New addition
Firstly I'd like to introduce myself. I'm new to this site and I'm from calgary alberta Canada.
I will be building a 8x10 mudroom off my 2009 house
Question is should I do a footing with concrete foundation wall tied into my current house or do post beam footing. Such as sono tubes filled with concrete ?
joecaption 09-08-2013 08:37 PM
Footing and foundation would be the best way.
Checked with your local code office to see what that say?
marklienhardt 09-08-2013 11:29 PM
That's what I'm thinking too. So If I do 3 foundation walls ( u shaped ) then having the 4th being the existing house,how would I insulate under the new floor ? My house is about 2' above grade. So ill have about 6' walls. 2' of that will be above grade.
Could I frame a entry way like a 2x2 hole in the foundation ?
woodworkbykirk 09-09-2013 04:33 PM
you really have to check the alberta codes, im on the east coast and were allowed to put a small addition on piers no problem.. the biggest issue is getting the right r value in the floor, we typically spray foam floor systems like this
Duckweather 09-09-2013 08:06 PM
Especially if you want it to stay attached to the house. No matter what, unless your new foundation is on the ledge it will settle a little, or more with sono tubes. I even used extra wide footings for additions, and strip footings instead of pads for lally columns.
marklienhardt 09-15-2013 09:50 PM
Thanks for you replies. Much appreciated you guys have any reviews on Screw Piles?
