New 4 Ply 2 X 10 Beam Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 01:32 PM   #1
New 4 ply 2 x 10 beam construction
I am building a cottage, the plans call for 3 beams to be made up for the floor to be built on. It calls for each one to be a 4 ply 2 x 10 beam of a 40 ft. length. What length of lumber would you use, how would you stagger it, and would you just nail it together or bolt it as well?
Rickyboy is offline   Reply With Quote
Old 12-27-2012, 05:27 PM   #2
Rewards Points: 502
If it's for a floor of 40ft span, 4-ply or any-number-ply 2x10s won't do, or have I misunderstood?
tony.g is offline   Reply With Quote
Old 12-27-2012, 05:30 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
do you have intermediate supports such as columns or piers? a 40' long beam as tony.g said is insufficient typically
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 12-27-2012, 06:08 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
your also not giving info on if its one story, 2 story, if there will be bearing wallls on the first floor or location.. all these determine beam size and maximum span
woodworkbykirk is online now   Reply With Quote
Old 12-27-2012, 06:11 PM   #5
Framing Contractor
Where on the plans are the columns/posts located ?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-28-2012, 10:43 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
it would be 4 piers (8' apart) with 16' lumber used to break on the piers. each ply- 16'x 16'x 8' lengths offset/staggered for each ply until all 4 plys are achieved.
hand drive is offline   Reply With Quote
Old 12-28-2012, 12:11 PM   #7
Civil Engineer
Rewards Points: 4,566
You say you have plans. Presumably these plans were developed either by an engineer or architect, who presumably developed the design based on the actual load of the house. It would be totally irresponsible for anyone on this forum to substitute their opinions for the actual design prepared by the professional who prepared the plans. If no professional prepared the plans, you have different issues, which likely cannot be addressed on an internet chat forum.
As to the proper method of fabricating the beams, that should have been specified on the plans, or possibly in specifications that came with the plans. Along with location, size, design, and attachment methods for any intermediate supports, and details for the joists. Forty feet is a long span, beyond normal tables, so design by a professional was appropriate.
Daniel Holzman is online now   Reply With Quote
Old 12-28-2012, 12:39 PM   #8
Rewards Points: 13,274
Even 2 X 10's sound light to me.
For runs that long I've been using LVL's or Gluelams.
I could buy them 40' long if that's what's needed.
Old 12-28-2012, 04:10 PM   #9
First pick the straightest lumber. You can account for some crowning, but at that length, you'll be building in errors. Designer called for 16' lumber, and I think that is due to his habit, but because you have supports every 8', you can make the beam with 8' or 10' lumber and may be decrease the number of plies you need, or keep it 4 plies for insurance. Joints must land on supports, if you choose to use short lengths. Exchanging 2x10 for 2x12 (have to change foundation pocket) is further insurance for future additions.
Each ply is overlapped at the half point, if you are using 16 footers. Use common 10 penny nails, about 1" from top/bottom edges. Even out the top edge as you nail. Then 1/2 bolts with washers every 16-18 inches, staggered. Lay out floor joists so nails/bolts don't coincide with joist hangers.
carpdad is offline   Reply With Quote
Old 12-28-2012, 05:30 PM   #10
Civil Engineer
Carpdad, what possible basis do you have to conclude that there are supports every 8 feet? And where do you see that the design called for 16 foot lumber? And why do you believe that the joints need to land on a support?
The OPS posted once, has not been back, and never stated what the support spacing is. Offering design advice for a 40 foot beam over the internet on a site you have never seen, and know virtually nothing about, is dangerous, and could lead to catastrophic failure if the OPS followed your directions, and it turns out they really do require a 40 foot clear span beam.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
woodworkbykirk (12-28-2012)
Old powder post beetle damage to beam in basement - is it really a problem? nezwick Building & Construction 5 10-09-2012 10:12 PM
Floor Flex with Car Deck / Post & Beam Construction george779 Tiling, ceramics, marble 3 05-09-2012 07:36 PM
Deck beam construction Fatboymm Building & Construction 2 05-08-2012 06:50 PM
Beam Replacement Popeye42 Carpentry 4 12-23-2010 11:29 AM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 11:50 PM
