Need Wall Surface I Can Texture. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2008, 12:03 AM   #1
Need wall surface I can texture.
I just moved into a 100 year old house. I'm in the process of remodeling the ceilings, floors, and walls. The walls are covered with crappy panelling that is very old and in some places it's loose and warped. Under the panelling the walls are solid 1" X 12" boards laid horizontally and they do have a very small space inbetween them of about 1/8" or so. I was thinking about sheetrocking the whole house so I can texture the walls but I'm wondering if there's something thinner, lighter, and less expensive than sheetrock that I can use. Is there some kind of panelling or similar product I can use. I just need a smooth surface that will hold texture. Thanks.
DVLCHLD is offline   Reply With Quote
Old 10-08-2008, 07:02 AM   #2
the Musigician
DangerMouse's Avatar
depends on what you mean by 'texture'. texture paint? plaster? maybe a nice 'spanish plaster' look? if i wanted to texture, i'd just put up chickenwire and plaster away. or, they make sheetrock 1/4", thinner and lighter weight. lots of options, i'm sure the guys here can add lots more. but what do i know? i'm just a mouse.
DM
Old 10-08-2008, 12:00 PM   #3
Keep in mind that the thinner you go the more likely you are to have a wavy wall. Aside from the fire protection of sheet rock one of the big advantages is that it evens out the wall so that it looks straight.
Other advantages to sheet rock other than fire protection is that it will help keep the wind out and the heat/cool in. It is also a good insulator from things like fire, heat and cold.
I don't know what the code is where you live but here you can put anything on the wall you want to. No need to sheet rock the walls. My brother in law just did a permitted remodel and he put OSB on the walls and then some roughcut Juniper we cut up on the saw mill. While it is a fire trap that is what he wanted and the inspector was cool with that.
As for texturing you can texture about anything. I have textured cardboard while testing the nozzle settings. I have textured sheet metal on duct work, did a TV once where the masking tape came off, did some furniture for the same reason, textured a plant, a few windows, and got my wife one day.
As long as it has a surface it can be textured.
The issue is will it stick.
Very smooth surfaces will not work well in the long run. Porous surfaces will do much better. Flexible surfaces will be problematic.
The best surface is porous, non flexible and has some roughness to it.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-08-2008, 03:47 PM   #4
Drywall contractor
Rewards Points: 1,068
I'd remove the "loose, warped, crappy" paneling and sheetrock the walls. Use 1/4", 3/8", 1/2", or 5/8" to get the wall back to where you started so your trim works out. Tape, bed and skim coat and you're ready for whatever texture you want. Good opportunity to add any new electric, cable, phone outlets you may want........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-08-2008, 07:25 PM   #5
thanks
Thanks for the info. I think I will go with 1/2" sheetrock.
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 12:57 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 05:09 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 04:50 PM
