Need To Tighten Spindles On Stair Rails. - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 06:02 PM   #16
Stairguy
Millertyme's Avatar
Rewards Points: 508
Dovetailed balusters of metal dowel inserts will help as will a beefier baluster like an 1-3/4"
Millertyme is offline   Reply With Quote
Old 02-01-2013, 06:09 PM   #17
Rewards Points: 13,300
I was thinking there and at the right angle turn.
Old 02-01-2013, 06:30 PM   #18
Rewards Points: 558
Newel posts similar to this installation should have been put in place to stop the wobbling.
epson is offline   Reply With Quote
Old 02-01-2013, 08:03 PM   #19
Rewards Points: 190
My DIL asked me to do something because they have a similar railing with thin spindles. With the grandkids riding trikes at high speed in the upstairs hall, she was afraid they would crash through the railing and fall to the floor below as they had already cracked one of the spindles.
I took a long 3/4" thick red oak board and ripped 3/8" thick strips off it. I placed a strip horizontally on each side of the spindles halfway between the top and bottom, and bolted them together with machine screws and washers every 18". Painted white, they don't look bad and they really stiffened the railing. Sometime in the future they can be removed with no damage to the railing.
zircon is offline   Reply With Quote
Old 02-02-2013, 06:07 PM   #20
Rewards Points: 664
Originally Posted by Millertyme View Post
I think it needs a newel at the top to anchor the rail. .
Thank you. How do I instal the newell post?
crescere is offline   Reply With Quote
Old 02-02-2013, 07:09 PM   #21
http://www.bing.com/videos/search?q=...post&FORM=VDRE
Old 02-02-2013, 07:21 PM   #22
This is not a great first time DIY job. Might want to concider hiring a real craftman on this one.
It can get expencive real quick if it's done wrong.
Painting the spindles of a stair case mimijack Painting 9 09-16-2012 06:17 AM
stair hand rails chulett Carpentry 30 04-10-2011 10:42 PM
building codes & Deck Rails with 3/4" aluminum spindles mroyten Building & Construction 8 09-20-2010 09:13 AM
stair spindles jimmyboy Carpentry 4 12-15-2007 04:17 PM
Wood Finish to Stair Rails propilot5000 Painting 1 01-09-2007 07:22 PM
