Need To Tighten Spindles On Stair Rails. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 05:46 PM   #1
Rewards Points: 664
Need to tighten spindles on stair rails.
I have a nice home from 1920 that I am leasing to tenants. There is a beautiful wood stair rail going up the stairs and along the side of the stairs. The city inspector said the railing is too loose and I must tighten it. The spindles are fully twisted in place. The railing is probably exactly like it was when put there over 90 years ago. If you were to violently shake the rail it may wobble, but it is not dangerous in my opinion. How do I firm this up without destroying the esthetics?
crescere is offline   Reply With Quote
Old 01-16-2013, 06:12 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
Please post pics
Millertyme is offline   Reply With Quote
Old 02-01-2013, 09:43 AM   #3
Rewards Points: 664
Here are pictures of the stair rail and spindles that the inspector says is wobbly.
Old 02-01-2013, 09:44 AM   #4
Rewards Points: 664
Overall. The inspecter can shake this if he tries hard enough.
Old 02-01-2013, 09:45 AM   #5
Rewards Points: 13,694
Need a picture of how the rails were attached.
Old 02-01-2013, 09:45 AM   #6
Rewards Points: 664
more detail
Old 02-01-2013, 09:46 AM   #7
Rewards Points: 664
upper attachment
Old 02-01-2013, 09:49 AM   #8
Rewards Points: 664
How can I secure these so the railing does not shake?
Old 02-01-2013, 11:00 AM   #9
Hopefully one of the real stair guys will post at some time to day.
First thing I see is two missing Newel post,
http://www.stairpartsusa.com/Stair_Parts_Newels_s/5.htm
Not sure how just using ballisters can keep the railing from moving.
Old 02-01-2013, 11:17 AM   #10
Rewards Points: 150
Agreed should've had a Newell post at top of stairs. To stiffen it
kaschmid3 is offline   Reply With Quote
Old 02-01-2013, 11:18 AM   #11
Rewards Points: 150
I would ask inspector if he had any suggestions that would keep the integrity of the time period and your house
Old 02-01-2013, 11:32 AM   #12
Only have pictures to go by, but are those ballisters orginal to the house?
Looks to clean to be that old. Older ones buy now would have had many layers of paint.
See any old black marks on the hardwood flooring where there may have been newel posts?
Old 02-01-2013, 04:33 PM   #13
Stairguy
Millertyme's Avatar
Rewards Points: 508
Those look like 5015 balusters and 6010 handrail. Run of the mill stuff still popular today
Old 02-01-2013, 04:39 PM   #14
So Miller would you build it like that one?
I'm just not seeing how ballisters that are just glued in at the top are going to keep that rail from moving.
Old 02-01-2013, 04:55 PM   #15
Stairguy
Millertyme's Avatar
Rewards Points: 508
I think it needs a newel at the top to anchor the rail. I did a job that was similar to that but they used square balusters. I used a solid steel baluster that passed through the tread and anchored to framing and one through subfloor on balcony and attached to joist. Made it easy seeing the floor wasn't down yet. Are those balusters loose at the bottom where they attach to the stair and balcony nosing
Painting the spindles of a stair case mimijack Painting 9 09-16-2012 05:17 AM
stair hand rails chulett Carpentry 30 04-10-2011 09:42 PM
building codes & Deck Rails with 3/4" aluminum spindles mroyten Building & Construction 8 09-20-2010 08:13 AM
stair spindles jimmyboy Carpentry 4 12-15-2007 03:17 PM
Wood Finish to Stair Rails propilot5000 Painting 1 01-09-2007 06:22 PM
