Need Tempered Glass Clarification - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-01-2011, 11:14 AM   #1
Need tempered glass clarification
I thought I had the requirement for tempered glass in windows understood, but then I came across this post in a DIY Chatroom thread called When is tempered glass required? from 2009:
The International Residential Code allows you to place a window as low as you want to the floor, and unless the piece of glass is 9 square feet or larger it doesn't have to be tempered.
That being said, if it is within 24" of an exterior door opening it must be tempered regardless of size or height.
If it is within 60" horizontally of a step or stair, it must be tempered if it is within 60" from the floor, regardless of size.
It's the underlined sentence that has me confused. It seems to indicate that one must have tempered glass panes for any size window located within 24-inches of a door leading to the outside/exterior of a dwelling.
If this is indeed true, I'd be very interested in knowing the safety concern here (what prompted this code requirement?).
I've been reading the 2009 IBC -- the prevailing code for Massachusetts -- and I'm not having much luck finding anything relating to tempered glass.
Thanks for any productive thoughts,
Red
Red Oak is offline   Reply With Quote
Old 09-01-2011, 11:33 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
You are correct in your reading of it, as i understand it.
I was under the impression it was prompted by injuries sustained by people running for doorways trying to get out quickly in an emergency, but can't remember exactly where i heard this. Could have been right here at DIY
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-01-2011, 12:20 PM   #3
door knob would do the trick
The older I get the better I was
Tempered or regular glass for tables? Sliding Man Interior Decorating 5 05-15-2011 06:16 PM
rule for tempered glass kloomiller Building & Construction 1 08-16-2010 01:17 PM
type of glass (tempered, laminated, etc.) myrtal Building & Construction 3 08-14-2010 09:03 AM
Tempered glass needed or not? DangerMouse Building & Construction 5 04-29-2010 07:34 AM
When is tempered glass required? vsheetz Building & Construction 4 01-17-2009 10:53 PM
