Need Suggestion .. Squr Hold In Ceiling On Stairwell - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 11:55 AM   #1
Question
Need suggestion .. squr hold in ceiling on stairwell
I bought a house and on the ceiling of the stairs going down to the basement there is a square hole with a junction box. I'd like to install some kind of lighting here, but not sure how to go about doing it. The picture tells the story. (I'm confident in my abilities to install light fixtures etc.. but not sure how I would install in this scenario.)
kiper is offline   Reply With Quote
Old 10-08-2011, 02:55 PM   #2
Rewards Points: 5,336
What you do will depend on the type of fixture you're installing and how big the hole is? It would help if you mentioned that.
You could probably install a surface mounted fluorescent, covering the hole. Fixtures smaller then the hole would require patching the sheetrock.
Ron
B. Franklin 1759
What to do with this old ceiling? mudworm Building & Construction 4 07-17-2011 04:54 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Suggestion for Deck Ceiling lucy brown Carpentry 2 09-15-2009 04:30 AM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 09:20 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
