Old 07-08-2011, 01:23 AM   #1
Need stucco advice
Hi, new home owner looking to remove some 3/4 inch decorative wood boards from the exterior of my home. The problem is, appears the previous owner put ~1/4 stucco on the inside borders of the wood. A bit difficult to explain - but essentially I believe my stucco will not be level once I remove the boards. (hopefully the pics help)
Any advise on what to do here to even things out? Any way I can grind down or remove the 1/4 inch of stucco? Or should I throw 1/4 stucco on top of the entire face of the house? Or do I have to remove all the stucco and do it all over again?
ar10 is offline   Reply With Quote
Old 07-08-2011, 06:45 AM   #2
Super Moderator
Need stucco advice
Sorry,I have no idea what you are trying to do---could you add details?
Old 07-08-2011, 10:45 AM   #3
Need stucco advice
Let me try again to simplify my question. Can you grind away an uneven layer of stucco? Or do I have to remove it and restucco everything?
Stucco cracks and stucco questions FrankL Building & Construction 2 05-22-2011 07:23 AM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 06:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 01:22 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 04:03 PM
cracked OSB under stucco! any advice? colley513 Building & Construction 2 07-12-2008 09:47 AM
