Need A "Speed Bump" To Direct Water Flow - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 02:49 PM   #1
bgbrown125's Avatar
Rewards Points: 27
Need a "Speed Bump" to direct Water Flow
Hello Folks,
Now that my garage is built, I need to build a concrete hump to help direct the water flow away from the open end of the garage (20 ft wide).
It is all on an angle as everything in western NC is.
The drive is asphalt and I need somwthing on the order of a speed bump to direct water flow that comes down the driveway to another area. Can you build a 2-3" high, ~ 6" wide concrete "dam" on top of the asphalt??
Any suggestions on how to tackle this would be apprecited.
bgbrown125 is offline   Reply With Quote
Old 08-07-2011, 04:22 PM   #2
Rewards Points: 5,336
Originally Posted by bgbrown125 View Post
Hello Folks,
I would have installed a linear grate in front of the doors leading to a drywell or directed it underground to a low point on the property.
You can still do it.
Ron
B. Franklin 1759
Old 08-07-2011, 05:42 PM   #3
AGWhitehouse's Avatar
I concur
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-07-2011, 11:12 PM   #4
Concrete & Masonry
Rewards Points: 530
I agree with Ron as well. You can't simply pour some concrete on top of oily asphalt & expect it to perform. You could remove some of the asphalt to get it keyed in, but at that point you might as well put the trench drain in.
jomama45 is offline   Reply With Quote
Old 08-08-2011, 01:24 AM   #5
Look up YouTube videos discussing ways to install a channel drain. That's exactly what you need. It's the drains that have PVC/Metal grates on top. Not too terribly difficulty to install.
JustADoc is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Removing water flow restrictors Alvis Plumbing 9 03-25-2012 11:09 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Tub hot water does not Flow at all (details enclosed) lisaz Plumbing 7 12-17-2008 09:16 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
