Need Soundproofing Ideas - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 09:06 PM   #16
Thanks Ted...What u think of this, i've purchased 50 sheets of Quite Rock 525, put a layer of q/r against the sub floor and use sound sealant, now what size insulation should i use, its 2x10 floor joist, and faced or unfaced,and use r/c with clips and a run of q/r 525....what would that accomplice Thanks
GDR1 is offline   Reply With Quote
Old 09-02-2012, 09:53 PM   #17
Soundproofing Guy
Rewards Points: 158
That would not work well. You need more mass (like from standard 5/8" drywall) and a damping compound. The system needs the damping compound in contact with the subfloor. So damping compound and more mass is needed under the subfloor.
R19 fiberglass.
The ceiling will be way too light with a single drywall layer. You'll want to add a sheet of 5/8" drywall, preferably with damping compound.
Ted White is offline   Reply With Quote
Old 01-05-2013, 01:07 AM   #18
Hello Ted, i've just install the insulation, i have puechased the rc2 channel, can i install this channel on 24oc, and another thing do i put 2 screws @ each joints it meets, i have purchded Q/R 5/8 for the ceiling,and can you tell me your thoughts of finishing the Q/R around the walls......Thanks
Old 01-05-2013, 01:12 AM   #19
Wow... guest i need to proof read.....lol
Old 01-05-2013, 06:23 AM   #20
Soundproofing Guy
Rewards Points: 158
GDR1- The RC-2 does not decouple, as long as you understand that. You would have to ask the manufacturer how they want it spliced. It is not a product we ever work with for several reasons.
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 09:10 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 06:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 08:07 AM
Garage shelving ideas koodawg General DIY Discussions 3 12-31-2010 09:52 AM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 08:36 PM
