Need Some Quick Help With Coffin Angles. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 02:39 PM   #1
the Musigician
DangerMouse's Avatar
Need some quick help with coffin angles.
I have a friend that's building a small coffin and he can't figure out the right angles to set his saw to to achieve these cuts. (A, B and C)
any help?
thanks!
DM
Old 01-27-2010, 04:09 PM   #2
Geometry sucks. Do you have the dimensions of all five sides. If you do then it is pretty easy ( I think).
warnerww is offline   Reply With Quote
Old 01-27-2010, 04:13 PM   #3
jlhaslip's Avatar
Rewards Points: 396
supply some dimensions and I can draft the outline which will provide the angles.
jlhaslip is offline   Reply With Quote
Old 01-27-2010, 04:16 PM   #4
Old School
Willie T's Avatar
Here's a typical layout.
1 & #2 = 49 degrees each
#3 = 80 degrees
#4 = 76 degrees
#5 & #6 = 53 degrees each
(Subtract from 90 to get the opposite angles for saw settings...... or JLHASLIP will soon have them shown here for you.)
Willie T
Old 01-27-2010, 04:23 PM   #5
the Musigician
Thanks Willie, that's exactly what I needed. Po)
and Thanks to everyone else too!
DM
Old 01-27-2010, 04:40 PM   #6
jlhaslip's Avatar
Rewards Points: 396
check this out
Bisect the angles and those would be the cuts.
Lengths would be the outside corners.
Old 01-27-2010, 04:40 PM   #7
Great drawing. Now I do not have to do geometry. Thanks
Tarkett Vanguard Quick Loc Hardwood Floor wlwin61 Flooring 96 01-18-2017 02:16 PM
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
Shaw vs. Quick Step melissamarie9 Flooring 12 09-17-2010 10:52 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 03:25 PM
Behr Quick Fix Deck Stain Remover mahjohn General DIY Discussions 1 12-04-2007 11:39 AM
