-   -   Need some quick help with coffin angles. (http://www.diychatroom.com/f19/need-some-quick-help-coffin-angles-62950/)
DangerMouse 01-27-2010 02:39 PM
1 Attachment(s)
I have a friend that's building a small coffin and he can't figure out the right angles to set his saw to to achieve these cuts. (A, B and C)
any help?
thanks!
DM
warnerww 01-27-2010 04:09 PM
Geometry sucks. Do you have the dimensions of all five sides. If you do then it is pretty easy ( I think).
jlhaslip 01-27-2010 04:13 PM
supply some dimensions and I can draft the outline which will provide the angles.
Willie T 01-27-2010 04:16 PM
1 Attachment(s)
Here's a typical layout.
1 & #2 = 49 degrees each
#3 = 80 degrees
#4 = 76 degrees
#5 & #6 = 53 degrees each
(Subtract from 90 to get the opposite angles for saw settings...... or JLHASLIP will soon have them shown here for you.)
DangerMouse 01-27-2010 04:23 PM
Thanks Willie, that's exactly what I needed. Po)
and Thanks to everyone else too!
DM
jlhaslip 01-27-2010 04:40 PM
1 Attachment(s)
check this out
Bisect the angles and those would be the cuts.
Lengths would be the outside corners.
warnerww 01-27-2010 04:40 PM
Great drawing. Now I do not have to do geometry. Thanks:thumbup:
