Need Some Compact Stair Case Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 09:33 PM   #1
Rewards Points: 198
need some compact stair case help
I've just recently purchased a 97 year old home in a historical area of washington dc. The problem i'm having is that the existing stairs is not installed properly and needs to go. However my opening is very narrow 2" and basement ceiling is only about 6'5. I initially thought about a spiral staircase option but it seems that my opening is too narrow. So i'm now looking at compact stairs http://www.misterstep.com/EN/product...mini-plus.html i'm wondering if anyone here has installed this as a DIY project? if so how do they function? also i'm open to other ideas. thanks much to your help
vote4Pedro is offline   Reply With Quote
Old 07-22-2010, 09:41 PM   #2
Existing stairs are usually grandfathered - can usually stay & not meet todays code
Once you take them down you may be required to meet todays codes for stairs
Better check 1st w/local building dept
The Following User Says Thank You to Scuba_Dave For This Useful Post:
BigJim (07-22-2010)
Old 07-22-2010, 09:43 PM   #3
I have never seen this product. It would actually work perfect for a loft that I am working on. I may check it out. As far as install goes, as long as your comfortable with it you should be fine. This is from their website:
Will I need the help of a professional fitter?
Generally this is not required. However if you have never used a drill, assembled a shelf/wardrobe or carried out any manual work, Rintal strongly suggests that you contact a professional. You can call your Misterstep dealer for more information on our installation services.
Justin08 is offline   Reply With Quote
Old 07-22-2010, 10:05 PM   #4
Rewards Points: 198
good point, i'm not sure. was under the impression that stairs are stairs.
Old 07-22-2010, 10:15 PM   #5
Rewards Points: 198
please let me know if you find it cheap stateside maybe we'll do a bulk order seeing you are in MD and i'm in DC
Old 07-22-2010, 10:25 PM   #6
New stairs need to be 36" wide
They also need a specific rise & run to meet code
2006 IRC regarding stairs
http://www.stairways.org/pdf/2006%20...C%20SCREEN.pdf
Old 07-22-2010, 10:48 PM   #7
Rewards Points: 198
it's going to be pretty hard to meet the height requirement as our basement is only 6'5
Old 07-22-2010, 10:49 PM   #8
That's why you need to talk to your local building dept
How do you paint an 18 ft high wall, along a stair case? Danijo Painting 13 07-19-2010 02:39 PM
Entry Stair Case ralphfravel Carpentry 1 11-04-2009 08:03 PM
Removing stair case yankep Carpentry 4 10-20-2009 10:55 PM
what's the safest way to install a chandelier over a stair case? diy'er on LI Electrical 18 08-01-2009 04:15 PM
some questions on stair case skirt boarding (how to measure, cut, materials) dwichman Carpentry 2 04-06-2009 06:40 PM
