-   -   Need some advice on venting a dryer. (http://www.diychatroom.com/f19/need-some-advice-venting-dryer-108833/)
John_W 06-26-2011 02:27 PM
6 Attachment(s)
Currently it vents into the crawl space through a hole in the floor. The hole is right over the sill plate. That area is blocked from access to the crawlspace proper by a floor joist. I don't want to cut a hole in the floor joist, and weaken the floor support, as that part of the laundry room floor takes quite a beating from the washer.
It seems like the choices are to:
1. Go out the wall behind the dryer (onto the front porch).This would be the easiest and is my preference. It will be a little unsightly, but we can live with that. If I can place the hole directly behind the dryer's vent, this could be a 'straight' shot. The dryer might have to be placed on a short stand to line things up.
2. Go up into the attic and down through a new soffit vent. This looks iffy because of a tight space where the wall meets the roof rafters. Plus, I don't like the idea of going upwards a 'long' distance with the dryer exhaust.
3. Go through the roof. I don't like putting an extra hole in the roof, so this option is not desirable either. Plus, it involves going upwards a 'long' distance with the dryer exhaust.
We live in northern Alabama, so we get heat, humidity, bugs and cold.
Please take a look at the pictures and tell me what you think I should do - including any details on routing the vent, locating the hole(s), how to cut and seal the holes, whether I need to use a double walled vent pipe (where it goes through the hole(s)), etc.
Thanks for your help.
John_W 06-26-2011 02:29 PM
Advice on venting a dryer - more pictures.
3 Attachment(s)
Here are the other pictures.
user1007 06-26-2011 03:03 PM
You do not want to be venting a dryer, with its lint, up into the attic or out the roof. Far from code compliant and a real fire hazard.
Distributing dryer lint on the outdoor stairs is not ideal and is going to add a maintenance chore but seems your best option.
Gary in WA 06-26-2011 04:04 PM
Up through the roof is code compliant, if under the maximum distance as per dryer manufacturer or local AHJ. http://docs.google.com/viewer?a=v&q=...up65cYgFwMvULw
Raising the dryer will help when transferring the clothes from the washer, I elevated mine on a plywood box years before the store-bought ones came out. A straight shot duct run is best, be sure to include the back-draft damper required by code on the termination hood (get a type "A"): http://www.appliance411.com/faq/dryer-vent-length.shtml
You may want to add a handrail to your front (public use) stairs for liability. Transition ducting is limited to one 8' section........ not as pictured.
Gary
High Gear 06-26-2011 04:04 PM
Venting to a front stairway entrance is ..well tacky at best , but I've seen
about as bad even on new construction.
If you notch the bottom of the joist and sister it for strength maybe you
have a better exit you could use.
Ideally a dryer vent should vent to the shortest path but you can run a
surprisingly long vent ( bends will shorten this length
( you dryer manual will show maximum lengths with max allowable bends ect.))
There are even duct boosters but I have no experience with them.
My run is probably a good 20'or more just to get away from this problem.
You will want to inspect your duct more often the longer the run.
hardwareman 06-26-2011 09:30 PM
its never ideal to run it up through the roof but sometimes that is your best option. In your case I would go through the roof, just make sure it is accessible for future vent clean out because you will be cleaning it out.
John_W 06-26-2011 10:42 PM
Gary
Thanks for the information and the excellent links.
That plywood base sounds like it might be sturdier than the store-bought metal ones.
If I go straight through the wall to the porch, the hole can be 3 feet away from the window, vertically, but will not be 3 feet away horizontally. Horizontally, it would probably be about 10 inches either side of the left side of the window (as viewed from the porch). Is that a problem?
Gary in WA 06-26-2011 10:55 PM
Only if you are getting it inspected...... it is a safety concern especially with a gas dryer due to the by-products from burning and being recir. through an open window. The window should be safety glazed for today's code, but only when selling- 5' up and 3' to glass;http://www.deckmagazine.com/article/54.html You may be required at selling to bring it up to code or a reduction price, also your H.O. insurance carrier may not honor a fire claim due to this paper trail you left......
better to do it right.
Gary
John_W 06-26-2011 11:04 PM
Thanks for your comments.
The 'sister' idea is a new one for me. If I did that, there would be two or three routes available through the crawl.
The straightest would be about 35 feet long and have 1 90 degree and 2 45 degree bends.
The shortest would be about 12 feet long and have 2 90 degree bends, 2 45 degree bends and require punching holes through two block walls plus the brick below the front porch. We could hide the vent behind a bush, so it might look better than the above-porch option.
My wife doesn't mind the idea of the above-porch option. She sees no problem with sweeping up the lint after the week's washing and drying are done.
I like the above-porch option because it will be something I am comfortable doing myself. The other options (roof and crawlspace) are a probably too much for me to attempt on my own.
John_W 06-26-2011 11:34 PM
Gary
So, sounds like I need to go through the crawl or the roof.
