Old 08-30-2011, 10:09 AM   #1
Need some advice on stair balusters and railing
Hello, I am just about to install my balusters, newel post and railing tonight. I bought a 48" newel post and my balusters are 34" I have 7 stairs with each stair having two balusters.
My question is this.... I purchased 11 34" balusters to complete the project. But i think I goofed up because there all 34" I did not get for each stair a 34" and 38" baluster. I did not think of that at the time.. If i go ahead and use two 34" balusters for each stair will that work out okay or do i have to use a 34 and 38 inch baluster for each stair tread? Thanks
tonyg1 is offline   Reply With Quote
Old 08-30-2011, 12:27 PM   #2
Okay, just in case I may have confused anyone. All I would like to know is if I use two balusters per stair tread can they both be 34" high or do you have to use a 34" and the other one 38"? thanks
Old 08-30-2011, 12:48 PM   #3
Experienced
Jackofall1's Avatar
The thickness of your upper handrail will determine how much you will have to cut off the balusters, as the top of the rail should be 34" measured from the front edge of the thread (step).
If your tread is 10" to meet current code chances are you will need (3) balusters per step to meet the 4" sphere clearance code.
Mark
Old 08-30-2011, 01:51 PM   #4
Thanks for the reply there mark.. I got ya on the 4" code and that I may need to add a third baluster if i dont make the 4" code. But what i am confused about still is I have read of course after i bought all the materials, that people use a 34" for the first baluster and the second baluster 38"... Of course all the balusters i purchased are 34". So my first and second baluster will be 34" which will work but is that okay to do it that way or do i need to return some of the 34" and buy the 38" ? thanks
Old 08-30-2011, 02:39 PM   #5
Experienced
Jackofall1's Avatar
Tony, The length of the baluster is determined by the space you have from the bottom of the rail (set at 34"- measured from the front edge of the tread to top of rail) to the tread.
For example if your rail was 4" deep, you would need a baluster starting at 30" and depending on the angle of the rail the balusters get progressively longer.
Make yourself a scale drawing of the rail set up and see what length you need, my guess you will need some 38" long balusters for the back postion.
Mark
Old 08-30-2011, 02:52 PM   #6
SteelToes's Avatar
If your top rail is at the same angle parallel with your stairs it should be all one size balusters.
SteelToes is offline   Reply With Quote
Old 08-30-2011, 02:56 PM   #7
Experienced
Jackofall1's Avatar
That would only be true if you had a bottom rail running parrallel with the top, not so with a single top rail with balusters to the stair tread.
Mark
Old 08-30-2011, 03:10 PM   #8
SteelToes's Avatar
Well depends on the turning length
Old 08-30-2011, 03:15 PM   #9
Experienced
Jackofall1's Avatar
The reference you are looking at is referring to the way the balusters are installed (which end is cut and how) related to a paticular style, but, the balusters are still at varying lengths.
Mark
Old 08-30-2011, 03:24 PM   #10
SteelToes's Avatar
Yes, but with the different lengths of the balusters design profiles would not end up spaced out the same, so you would have to get the same size baluster and accommodate for the difference trimming the bottoms, no ?
Old 08-30-2011, 03:28 PM   #11
Experienced
Jackofall1's Avatar
Yes now I understand what it is you are getting at, the turned length is the same but the OA is changing, and I was thinking purely about OA length.
Mark
Old 08-30-2011, 03:32 PM   #12
SteelToes's Avatar
When its all said and done there is usually more said than done...
Old 08-30-2011, 07:01 PM   #13
STAFF
BigJim's Avatar
34 inch balusters will be too short for two of the balusters with three per each step. Read what the first illustration says in Steeltoes post about the difference in length of each baluster. Depending on the style post you have and your rise, and the way you mount it, 48 inches may be too short for your post also.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Repair / Replace Deck Railing & Balusters cs006b Carpentry 3 09-05-2010 12:07 PM
Matching a Stair Railing HandyMartin Carpentry 2 08-15-2010 11:48 AM
Questions about stair railing decru Carpentry 1 11-07-2009 11:23 PM
stair railing rocksaranac Carpentry 5 04-29-2009 10:42 PM
replace wood railing balusters jad Remodeling 2 04-01-2009 12:24 PM
