Old 08-31-2009, 11:40 PM   #1
need to slightly raise deck surface
On part of my redwood deck I'm going to remove the surface and replace it with plywood. The plywood will then be coated with a waterproof surface so that I can use the area below as a carport. But there is one slight problem... I'd like to raise the plywood deck surface slightly (like 1/8" to 3/16") and I'm not sure how best to accomplish it. In other words, I want the plywood surface to be slightly higher than it would be if I were to attach it directly to the joists. Any suggestions? Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 08-31-2009, 11:59 PM   #2
Moderator
Termite's Avatar
Treated lumber furring strips can be nailed to the top of the floor joists before you lay down the plywood. Cut them on a tablesaw out of 2x4, 2x6, or whatever is cheapest. Problem solved.
Now, plywood? Outdoors? It will not hold up. Even treated plywood doesn't last outdoors, it isn't designed for it. The wood may not rot if you use treated plywood, but it will certainly delaminate. At the very least, a good bitumenous rubberized membrane of some sort (or even rolled roofing) is in order underneath the decking to make the carport a little more water resistant.
Old 09-01-2009, 05:47 AM   #3
'mite, we've used this product successfully on ply decks - http://concretecoatingsofgeorgia.com/gulf_synth.htm -
agree w/your plywood comment however marine ply's another factor,,, nevertheless, we've used gulf & i'm always a skeptic,,, no financial interest other'n they've got a good product, imo spray, roller, or brush. & even comes in colors,,, pedestrian traffic compatible altho no experience w/auto.
itsreallyconc is offline   Reply With Quote
Old 09-01-2009, 10:44 AM   #4
Thanks for the suggestion. No table saw, so it'll be a challenge cutting these with my circular saw, but I think I can manage it.
As for plywood outdoors, it'll be coated with a polyurethane system designed for just such an application:
http://www.cadeco.com/productfiles/S...-Sonoguard.pdf
The result is a walk-on waterproof surface. In fact, several of my neighbors have used this (or similar) systems with great success. Btw, it rains a lot around here in the winter (N. California, in the redwood forest), so I don't think it's any fluke that these have held up well over many years.
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
correcting slightly uneven small concrete surface amakarevic Building & Construction 5 01-16-2008 08:38 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck surface mt232 General Discussion 11 05-01-2007 03:32 PM
